Overheating
Results 1 to 7 of 7
This is a discussion on Overheating within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 02 WRX NB-R and it has started overheating. The gauge doesn't really go past half way but ...
    May 2009
    Kenya
    Unhappy Overheating
    I have an 02 WRX NB-R and it has started overheating. The gauge doesn't really go past half way but when I turn off the engine all hell breaks loose and all the coolant and water comes boiling out. I got the thermostat removed (it was stuck) but that didn't solve said problem. I was told that if it was a head gasket then there would be white smoke form the exhaust. Somebody? Anybody? Help?
    Flirty User That's Younger Than the Chunks of Corn in Brian's Crap
    WRXie's Avatar
    Mar 2009
    Down South
    Mine was spewing coolant everywhere because I had a hole in my radiator and I had overfilled my coolant. Maybe something like that?
    2002 WRX Yellow Blaze
    Bugeye Mafia #216
    High Mileage Club
    May 2009
    Kenya
    WRXie
    Was the coolant coming out of the hole in the radiator? Mine's coming out of the tank beside it (sorry dunno what exactly that tank is called)
    WRXie's Avatar
    Mar 2009
    Down South
    Both. I had a leak in the top corner of the radiator by the coolant holder thing and I had overfilled on the coolant so it coming out of there as well.
    Bugeye Mafia #216
    High Mileage Club
    May 2009
    Kenya
    I'll check for a leak in the radiator and I'll also check through the hoses to see if any of them are leaking.
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    Also burp the cooling system. If the coolant wasn't filled correctly you can get air pockets in the system. There's a pretty specific procedure for the turbo engines.
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by Batfink2002 View Post
    Contrary to pretty much every other engine out there 90% of Subarus with blown HG's end up leaking externally both coolant and/or oil...Obviously if you have an external leak and not an internal one you wont be burning any coolant/oil...As mentioned try what others have suggested such as burping the system, inspecting things etc etc..because obviously worse comes to worse you'll need head gaskets ( which is a somewhat rare occurance on Turbo Subarus..I think Ive seen like 2 Turbo Subies with popped HG's compared to the hundreds of N/A subarus ive seen with HG problems)
