Problem solved... just booked an appointment with my local tuner/mechanic to do the job.
After finding out how much the cam wrenches will be, forget it, ill pay the extra few hundred and enjoy the convenience of letting someone else doing it.
This is a discussion on Cam / crank pulley removal. Quick ?s !!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; gotcha...
gotcha
MY LUG NUTS NEED MORE TORQUE THAN YOUR HONDA MAKES!!!!
Cobb Stg 2 helix up/dp combo
Kartboy short shifter
2005 WRB WRX "was" STAGE 2
The easiest way to get the bolt off the crankshaft pulley is to get a friend and have them put the car into 5th gear and step on the brake, makes it much easier to pull it off! Hope this helps
Good chioce if you know you can trust them to do the job correctly, I wish the guys in NJ (Precision Tuning) were closer to me and I would have had them do the job, becasue quite frankly its a big PITA and you must have at least 1 other person to help out and or proper tools other wise you would screw it up, but presonally I didn't know a mechanic that could do a better job than myself and that would be trustworthy.....and the times that I saw how they work on cars I know better then to give them my car.
