Results 1 to 10 of 10
This is a discussion on running while not fixed? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; what will happen if the engine is ran with a number 4 misfire...
    Jun 2009
    dover, afb
    Registered User turbotwist's Avatar
    Dec 2008
    ri
    Quote Originally Posted by smugglin1986 View Post
    you will damage it more and more especially if you are seeing alot of boost. Had the same code and ended up having low compression in that cylinder. It dropped more and more and ran worse the more I drove it
    0db
    0db is offline
    Mar 2003
    Ventura, CA
    Quote Originally Posted by turbotwist View Post
    To be fair, if it's misfiring due to low compression, there's something mechanically wrong with the valvetrain or piston/rings, and that will ALWAYS get worse over time.
    If he's just got a bad coil or sparkplug, it probably won't hurt anything although if he's dumping unburned fuel out into his exhaust he could damage a catalytic converter or cause other problems.
    It's always best to fix stuff ASAP though. Just as a general rule.
    Oct 2005
    Late Devonian
    It could be a ton of basic issues if it is mechanical, many of which could be serious. Check all the basics as mentioned, MAF cleaner, fuel filter, spark etc. etc.
    Or it could be that the sensor is too touchy in your car. I guessed you had an '02 before I looked. There is a flash available from the dealer for an issue with this. Do you have an aftermarket flywheel and or pulley setup?
    Jun 2009
    dover, afb
    i have no idea if the previous owner did anything to the tranny or not
    Registered User UncleMidriff's Avatar
    Jun 2009
    Oklahoma City
    Shortly after purchasing my 03 WRX, I started having number 2 misfires. When the check engine light came on, I'd schedule an appointment with the mechanic, but still drive the car to work and around town until then.
    After the second CEL (same problem, number 2 misfire), the car began overheating badly. When I got it towed to the mechanic, they did some investigating and found out that piston number 2 was cracked.
    So yeah, it could be relatively minor or it could be something major. I'd get it checked out if I were you.
    Dec 2008
    ri
    why dont you get it checked out?
    Jun 2009
    dover, afb
    i will this weekend and roughly how much do you think it will cost to get it fixed
    Dec 2008
    ri
    totally depends whats wrong. expect to pay at least $85.00 an hour for diagnostic work
    Jun 2009
    dover, afb
    ok well what is the cost for a valve train fix
