Secondary air injection aka smog pump need some help
Results 1 to 5 of 5
This is a discussion on Secondary air injection aka smog pump need some help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok well i have cel due to secondary air injection switch bank 2 Stuck. im looking for a diagram of ...
    Registered User joosky's Avatar
    Jul 2009
    Ohio
    ok well i have cel due to secondary air injection switch bank 2 Stuck. im looking for a diagram of the secondairy air injection system. and or a "how to" on deleting the whole system and any hardware needed (yes i understand it is not legal).
    (06 WRX)
    Aug 2008
    Kennett Square, Pennsylvania
    What code did you get exactly? how many miles are on the vehicle? first thing i would do is a visual inspection of the system..than I would plug in the green diag connectors. the 2 SAI valves/switches that are on the drivers side kind of under the intercooler/intake manifold should be clicking when you plug those diag connectors in... See if they make a clicking sound ( you might have to use a long screwdriver or mechanics stethoscope to hear them)...
    Jul 2009
    Ohio
    the car has 43k miles on it. i wont be able to do any further diag untill thursday. i will re-pull the code and post it...
    thanks for the help so far
    Mar 2007
    I have a secondary air injection system switching valve stuck closed Bank 2 code in my 2007 WRX with 85K+ on it.
    Now what? Sounds like I might need a new valve or valve/solenoid or whatever. Is it tough to change? Any tutorials around on that one? I did a search to find this thread and didn't see any.
    Suggestions?
    Oct 2008
    ACT
    There's a thread on IWSTi.com about deleting the pump.
    Think this is it;
    http://boardreader.com/fp/IWSTI_com_...ts_888728.html
    Can't double check as it gets blocked here...
    And Cosworth make these;
    http://www.vividracing.com/catalog/c...7-p-53582.html
