more P0171 trouble!
Results 1 to 6 of 6
This is a discussion on more P0171 trouble! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 2004 wrx, with 56,226 miles. still getting a P0171 code after i installed the oem airbox. I am completly stock, ...
    Registered User phernic's Avatar
    Mar 2009
    Alexandria, Virginia
    more P0171 trouble!
    2004 wrx, with 56,226 miles. still getting a P0171 code after i installed the oem airbox. I am completly stock, except for axle back exhuast. Dont even have a K&N air filter, so any suggestions on what or where i can begin?
    thanks!
    -vic-
    Aug 2008
    Kennett Square, Pennsylvania
    double and triple check that ALL vacuum/intake hoses/lines are connected properly and not damaged...did you clear the code after installing the airbox?
    Makes sure the cover for the air box is seated correctly in the tabs.
    Clean the MAF very carefully.
    Check the tubing to the fuel pressure regulator.
    Frequently it's the MAF plus a dirty intake or air filter.
    Mar 2009
    after going back to stock, i cleared the codes, and about two days later the 171 code came back. Checked, double checked, then re-checked my workmanship. Was thinking about cleaning the MAF, but not sure how to. sounds like a good place to start, but what or how do you clean the MAF, bcs i know you not suppose to touch it, and if you do, dont touch any of the small wires, ect. is their a solution or spray of some sort? thanks
    -vic-
    PS:
    SD GR,
    where do i look for "the tubing to the fuel pressure regulator and what should i look for?"
    Dec 2003
    Dallas, TX / Sterling, VA
    Quote Originally Posted by phernic View Post
    how to clean MAF? - NASIOC
    Ignore the people saying to use brake cleaner.
    PS:
    SD GR,
    Look low by the intake manifold and "under" the inlet tube.
    Also for more info on P0171 see here but suspect the MAF sensor first IMO:
    P0171 CEL Thread - Everything you ever wanted to know? - NASIOC
