Results 1 to 9 of 9
This is a discussion on Misfire in cylinders 1,2, and 4 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello everyone, my car threw a CEL like always , i got out the scanner and got cylinder misfire in ...
    Registered User wrxwagon2's Avatar
    Feb 2009
    allentown,pennsylvania
    Hello everyone, my car threw a CEL like always, i got out the scanner and got cylinder misfire in 1,2,and 4. it did this before i had a misfire in 1 and 3 so i changed the plugs and the CEL went away. Now its back on. What should i do?
    2004 WRX (currently driving)
    2000 Audi S4 APR tuned (sold)
    2002 WRX wagon ( sold )
    1988 Thunderbird Turbocoupe
    Aug 2008
    Kennett Square, Pennsylvania
    Is the car actually missing? like do you hear/feel it? Im assuming all of the plugs are new? do you notice a lack of power or anything? does it miss all the time or just under load? how many miles are on the car? How long ago did you install the plugs?
    Feb 2009
    its not missing, a little power decrease, i changed them 300 miles ago, theres 102,000 on the car.
    Aug 2008
    Personally, I would clear the code and see if it comes back if you dont hear it missing at all...Did you clear the code after you replaced the plugs or did the CEL just go out?
    Feb 2009
    CEL just went out. The guy at autozone said and i qoute " yeah man needs new plugs and wires" but i just said ok because i just wanted the code. The wrx has coil packs. so theres no wires right
    Aug 2008
    correct...coil on plug...you could always swap the cyl #1 and cyl #3 coils and see if the misfire follows it..however i would find it hard to believe that like 3 coils would go out at once...Did you replace with stock plugs?
    Feb 2009
    im gonna try resetting the computer, but yes the plugs were replaced with the stock plugs.
    Registered User fire_cky's Avatar
    Jul 2007
    Philly
    i had this exact problem back in january on my 2002 wrx wagon, except it was cylinders 1,3, and 4. took it to the dealer, turns out there was an update for the computer which solved the issue.
    '02 wrx wagon:
    various cobb things here and there.
    LoneWolfBugeye #01
    Jun 2008
    Quote Originally Posted by wrxwagon2 View Post
    This has been discussed in a previous thread at lenght.
    Stumped with a misfire problem
    Check it out. Lots of good info.
