Radiator problems...need help asap!!
Results 1 to 5 of 5
This is a discussion on Radiator problems...need help asap!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 2002 wrx. Swapped out my radiator for an 04-05 sti radiator due to the fact that mine ...
    Registered User bluedevil21's Avatar
    May 2009
    Unhappy Radiator problems...need help asap!!
    I have an 2002 wrx. Swapped out my radiator for an 04-05 sti radiator due to the fact that mine had a hairline crack on the top. But now with the sti one installed my car is overheating worse than when i had the old one on. Need advice please!!!
    Burp the system thoroughly. Then burp the system again. Then repeat.
    May 2009
    i hate to sound like a noob but how do i do it and should i put my old one on if it doesnt work
    Dec 2003
    Dallas, TX / Sterling, VA
    Quote Originally Posted by bluedevil21 View Post
    lol. You have to get rid of all the air in the system if you want it to work properly.
    1. Fill
    2. Keep the cap off and turn the car on
    3. Everytime the coolant level drops add more
    4. Rinse-repeat till the fluid stops dropping.
    Watch the temp gauge while it's being done too.
    Aug 2008
    Kennett Square, Pennsylvania
    fill up the radiator all the way until it starts to come out of the filler neck, than continue filling from the surge tank... LIS-24610 Lisle 24610 Lisle Spill Free Cooling System Funnel - tooldesk.com I recently bought one of these...great investment ...If you get a stubborn air pocket i usually give it a good shot of the throttle a couple times and usually its enough to blow the air bubble out of the system... Also as mentioned watch the temp gauge..until i consider the job complete...I usually wait for the fans to cycle on and off and make sure there blowing hot air...
