Gauge lights dont work
Results 1 to 7 of 7
This is a discussion on Gauge lights dont work within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my clock didnt work along with my gauge lights and it kept blowing the 10A fuse for the Illum. spot. ...
    Jul 2009
    my clock didnt work along with my gauge lights and it kept blowing the 10A fuse for the Illum. spot. i changed the clock and still no luck. any ideas?
    Jul 2009
    I have the same exact problem with mine let me know if you figure anything out.
    Registered User vttk_mig69's Avatar
    Jan 2008
    Sheboygan, WI
    Either you have a short in the wiring or with all your gauges hooked up to the illuminatoin fuse your drawing to much power though that fuse either put a bigger one in or wire your gauges up seperatly to a standalone fuse.
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    Quote Originally Posted by vttk_mig69 View Post
    I think he just means the stock gauge cluster, not aftermarket gauges.
    If the fuse keeps blowing you must have a short somewhere.
    Jul 2009
    there are no aftermarket gauges just the stock cluster. im thinking there is a short from the clock to the gauges
    Jul 2004
    Seattle, WA
    Do the lights on the gauge cluster illuminate for a short time after replacing the fuse?
    How about the clock?
    Check all the wires leading to/from the gauge cluster. Also check the light bulbs.
    If the clock never turns on you might need to fix the weld points (common issue on Subaru clocks).
    http://www.scoobymods.com/overhead_c...ighlight=clock
    Jul 2009
    i just replaced the clock with a new one and the lights dont come on after replacing the fuse, the fuse just blows instantly by putting it in
