How to change the valve cover gasket
Results 1 to 15 of 19
This is a discussion on How to change the valve cover gasket within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi all i own a MY99 WRX and i have noticed that it's leaking oil from the drivers side valve ...
    Jul 2009
    hi all
    i own a MY99 WRX and i have noticed that it's leaking oil from the drivers side valve cover gasket - well from one of the bolts actually ..
    i have ordered the valve cover gasket kit for both right and left
    does anyone know the steps i need to take to change the valve cover gasket on the drives side ?
    thanks in advanced
    cheers
    Justin
    Is in Love With the Admins Here 20WRX04's Avatar
    Nov 2004
    WNY
    It's a tight fit to get tools/hands in there but you should be able to get the bolts loosened & out w/o having to lift the motor up. 1. Take the bolts out
    2. Take the valve cover off
    3. Toss out the old gasket
    4. Clean head mating surface
    5. Install new gasket into clean valve cover
    6. Put cover back into place
    7. Replace bolt gaskets
    8. Tighten to spec
    9. Enjoy!
    The first rule of the Faction is...DO NOT TALK ABOUT THE FACTION.
    NY GIANTS
    Hybrid Faction #19
    Blobeye Syndicate #19
    Mods
    Jul 2009
    Quote Originally Posted by 20WRX04 View Post
    8. Tighten to spec
    9. Enjoy!
    hi there thanks for that quick reply .. nice work ..
    do i have to also glue the gasket and spark plug seals and bolt seals on ?
    and do i need to take out the plugs to remove the valve cover?
    thanks mate
    Juz
    Nov 2004
    WNY
    Quote Originally Posted by justinc1981 View Post
    thanks mate
    Juz
    You're very welcome. It's a pretty easy job. Shouldn't take more than an hour or two. No glue or RTV needed. You should be able to leave the plugs in as well.
    NY GIANTS
    Hybrid Faction #19
    Mods
    Jul 2009
    Thanks once again .. yeh i have had a look and it looks like there is enough room to swing my tools and get the cover in and out all sorted
    and if i can get away with leaving the plugs in that bonus
    i noticed it's a bit of a design fault because directly under the value cover in the heat of the exhaust baking the gasket
    oh well an hour or 2 is great i'll have it done in an afternoon after work
    thanks
    Juz
    Jul 2009
    8. Tighten to spec
    just trying to find the bolt specs for the cover bolts and all i can find is 5Nm ... does that sound right ?
    does anyone know the specs on the cover bolts ?
    thanks
    Justin
    Nov 2004
    WNY
    If that equates to about 4 ft/lbs, then yes.
    NY GIANTS
    Hybrid Faction #19
    Mods
    Tightening torque for rocker cover bolts for 2.0L 2001+ turbo motor is 5 Nm or 0.5 kgm, and this seems to translate to 3.6 ftlbs. Factory manual ME(D0HC TURBO)-61.
    - Al Stewart
    Jul 2009
    yes just worked out that 5nm = 3.687 ft/lbs
    thanks guys
    off to now find a wrench that'll go that low
    Justin
    Nov 2004
    WNY
    thanks guys
    Justin
    You can probably do it by feel. 4 ft/lbs isn't much at all. Good luck.
    NY GIANTS
    Hybrid Faction #19
    Mods
    Jul 2009
    Hey guys
    someone was telling me that i should/could disconnect the negitive battery lead before i work on the car .. do i have to ? .. and will this stuff with the security keypad .. and the codes and all that?
    thanks
    Justin
    Nov 2004
    WNY
    The only time i've disconnected my battery terminal was when I took my engine out. You're not working on anything electrical but it's entirely up to you.
    NY GIANTS
    Hybrid Faction #19
    Mods
    Registered User Pesche02WRX's Avatar
    Mar 2010
    Chicago
    I know this is old but
    can this be done without lifting the motor on an 02 WRX 2.0?
    Bought this car 10-18-01 and never looked back...
    Apr 2011
    Jacksonville, FL; Flint, MI; Charleston, SC
    Quote Originally Posted by Pesche02WRX View Post
    Ya I would like to know as well. I will be checking this weekend to see if there is enough clearance to get some hand tools in there and pull the valve cover out. If there is I'm going to order the gasket set and I'll post some pics once it gets that far. It sounds like what everyone is saying in this thread is referring to the same motor or close to the same set up as an 02 WRX. We shall see
    Yes, you do not have to remove the motor for this job. It is not easy to do because of the lack of space to work, but it is perfectly feasible. It's just not much fun.
    - Al Stewart
