Changing Valve Cover Gaskets
Results 1 to 4 of 4
This is a discussion on Changing Valve Cover Gaskets within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi all i own a MY99 WRX and i have noticed that it's leaking oil from the drivers side valve ...
    Jul 2009
    hi all
    i own a MY99 WRX and i have noticed that it's leaking oil from the drivers side valve cover gasket - well from one of the bolts actually ..
    i have ordered the valve cover gasket kit for both right and left
    does anyone know the steps i need to take to change the valve cover gasket on the drives side ?
    thanks in advanced
    cheers
    Justin
    Nov 2008
    I dunno need you to take engino off from chasis, but I exactly know that this is not gasket problem. there are bolts with strange shape. you have to remove only the bolt, then you'll see that it's made the way that you can't retighten the gasket.
    you have to remake it and cut amout 1-1.5 mm of material from fat side of the bolt, so the thread side will become longer. then just retighten it.
    I hope you got it
    Quote Originally Posted by justinc1981 View Post
    hi all
    i have ordered the valve cover gasket set for both right and left
    thanks in advanced
    cheers
    Justin
    it may be possible that your rocker is just loose, which is can easily be fixed.
    Registered User tarmacsti's Avatar
    Dec 2007
    South Africa, Jo'burg
    +1 torque tighten the bolts until the gaskets arrive...
    Then see if you can get to all the bolts with the ability to unscrew them and do the entire process without removing the motor.
    **__The Hawk-Eye Alliance__**
    Member #0135
