| Home | Forums | Photo Gallery | Groups | Shirts and Stickers | Advertise |
| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here! |
| Advertise On ClubWRX | ||
LinkBack | Thread Tools | Rate Thread | Display Modes |
#1 (permalink) |
CEL and flashing cruise control
So I was driving from Dallas to Austin with the cruise control on. I sped up to pass some one and mid pass the car kinda jerked and the CEL came on and the cruise control light started flashing. So I instantly let off the gas and pulled over to check it out. Car was still running fine and a quick look under the hood I couldnt find anything major. So I slowly made my way to a local mechanic. He pulled the codes (I managed to get a quick glance at the computer and I think the code was P0244) and said something along the lines of a turbo solenoid (his english wasnt that great) and said the car should be safe to drive and to just do my best to keep it out of boost. after about 40 hours (many times of driving the car) the CEL turned off and my cruise control was working again
. So I drove from austin to san antonio (where i live) and then the light randomly came on again the next day and my cruise control wouldnt work again. then after about another 12 hours the light was back off again. And everything was back to normal.The car is a 06 WRX with 41,0xx miles on it. I was hoping if anyone could let me know what they think and if this would be covered under the power train warranty? Am I ok driving it around or should I not move it until I can get it over to the dealership? If it isnt covered under warranty what do you guys think im looking at cost wise to fix this? |
#2 (permalink) |
Same thing happened to me a while back.... boost spike is what we came up with. Did you happen to look at your boost gauge to see what it was "stuck" on? Mine did it at 1.49 bar. Think thats all the IWG is good for....
Not a BIG deal IMHO....
__________________
Paul 2007 MS3 Maintenance schedule and poke in the eyes: http://www.clubwrx.net/forums/genera...nce-guide.html |
#4 (permalink) |
Maybe they tapped the boost gauge wrong or something....I could be wrong but i believe P0244 is a wastegate solenoid code... It cant hurt to take a look over the system to make sure everything is hooked up properly and there are no loose/cracked/damaged vacuum lines...Have you gotten on it again since the code appeared? If so what happened? anything?
#5 (permalink) |
Any mods done to the car ?
By "stuck" I meant... Did you notice the psi it was on when it spiked ? 15psi shouldn't be enough to trigger the wastegate to stay open... but maybe. Wait for Donkey to respond. Nevermind.. no mods.... did you buy it new ?
__________________
Paul 2007 MS3 Maintenance schedule and poke in the eyes: http://www.clubwrx.net/forums/genera...nce-guide.html Last edited by pzr2874; 07-05-2009 at 09:28 PM.. |
#6 (permalink) |
no its used. 1 owner, lease return. Ive been trying to see if it does it again by going WOT but ive only had a chance to do it in the lower gears. No repeats yet but ill try it again tomorrow in 5th. This should be covered under the powertrain warranty right?
#7 (permalink) |
hey i had the exact same thing happen to me but it was after i put a downpipe in and it was the a/f ratio i got it tuned and the problem went away maybe ur car had a dp on it befor and the owner just replaced it with the stock and never relashed it back to stock. and yeah to be safe stay of on boosting high
#8 (permalink) |
Warranty would cover it... they can see if it's flashed or not.
__________________
#10 (permalink) |
What r u going to use to flash it ?
__________________
#11 (permalink) |
EDIT :
Well I just took the car out and I can recreate the CEL basicly on command. cruising 5th gear at about 60 go WOT and at about 80 the ECU cuts fuel, boost gauge never went over 15. Took the car to the dealership they said if its the solenoid the warranty doesn't cover it. but if its the actual waste gate its covered. Charging me $85 for the diagnostic but if it is the waste gate I wont have to pay it. Im going to be dropping it off tomorrow unless you guys have any ideas. Last edited by Mehdik; 07-06-2009 at 11:09 AM.. |
#12 (permalink) |
I'm new around here and don't even have a wrx yet, but I've been doing countless searches on many websites to learn as much as possible before buying. I remember seeing a post from someone on NASIOC about how they kept throwing this code intermittently and couldn't figure it out. It turned out to be a leaking vacuum/boost line in the wastegate/BCS circuit. Check all the lines into the BCS and wastegate and make sure they don't leak at all or have any cracks. Tighten clamps where appropriate.
#13 (permalink) | |
Moderator
Great info, thanks for posting and welcome!
SD Quote:
__________________
I want to be Caliph instead of the Caliph! Iznogoud He who drifts drives slowly. Walter Roehrl Νους υγιής εν σώματι υγιεί. Mod, New Member Hangout, Southwestern region, International |
#14 (permalink) | |
Quote:
im going to go buy some clamps.can anyone post me a picture on how the little pipes are supposed to be routed? |
#15 (permalink) | |
ClubWRX Grammar Czar
Quote:
__________________
- Kevin ....... '06 SGM WRX - VF39'd @ 293whp 346wtq 13.6 @ 98mph 1.8 60ft @ 6000ft Elevation Your friendly Colorado Moderator - Colorado Member's Forum Sponsored By: BreakThru Motorsports.com and WRXPro.com AIM: SinisterSooby |
| Bookmarks |
| Thread Tools | |
| Display Modes | Rate This Thread |
