ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > General Maintenance, Troubleshooting & Accidents.
General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here!
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 07-06-2009, 09:24 PM   #16 (permalink)
Im still going to take it to the dealer tommarow, I hooked up the tubes and the CEL went off but power delivery isnt nearly as smooth. the car kinda rocks front and back while under WOT I dont know how to explain it. Also its not boosting nearly as much, I dont think I saw it go over 8. I assume this isnt normal? Ive never owned a turbo car so I dont know.
Mehdik is offline   Reply With Quote
Old 07-07-2009, 07:22 AM   #17 (permalink)
I had a nice reply all typed out, but I can't post links without 3 posts, so...
postcount++
Ruiner46 is offline   Reply With Quote
Old 07-07-2009, 07:23 AM   #18 (permalink)
Ok, here it is:
Glad I could help. Sounds to me like your BCS isn't hooked up properly or isn't working properly. You should have a vacuum line running from the wastegate actuator to a tee. One side of the tee goes to the turbo or piping very close to it, and the other side goes to the BCS. On the other side of the BCS, there should be a line plumbed back into the intake tube, pre-turbo. Make sure the wiring to the BCS is plugged in and looks ok. Read this link and take a look at the pic. The BCS is the wastegate solenoid valve.
Boost Control FAQ: Read if you are thinking of buying one! - NASIOC
This next thread has some useful pics showing locations in the engine bay, but the thread is about installing a GM BCS as a mod.
Full DIY: GM solenoid install (56k warning) - NASIOC
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cel popped up w/ cruise control flashing...please help me!!!!! subypearson Tuning: Electronic Engine Management 3 04-01-2009 07:07 PM
flashing cruise with NO CEL?? happasaiyan STi Technical Forum 20 02-15-2008 09:39 AM
Steady CEL and flashing cruise control Help!!!!!! Mrdolla Maintenance, service, and repair 4 01-16-2007 11:37 AM
think i just had boost creep...cel on and cruise flashing? ronbang Engine Modifications 14 05-15-2006 06:16 PM
CEL and flashing cruise light w/ Godspeed DP copracer288 STi Technical Forum 9 12-04-2004 05:51 PM
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
