| Home | Forums | Photo Gallery | Groups | Shirts and Stickers | Advertise |
| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here! |
| Advertise On ClubWRX | ||
LinkBack | Thread Tools | Rate Thread | Display Modes |
#1 (permalink) |
i got an 02 wrx...when i first got the car it wasn't throwing out codes, but when i checked out under the steering column there was a disconnected wire, when connected it threw out a code, pretty sure its the o2 sensor, but idk...NEED ADVICE
#3 (permalink) |
Sammich Makin Pwincess #1 |
there are "test mode connectors" under the driver steering column. these are supposed to be connected to flash your ECU. they should be green in color & when hooked up put your car in test mode.
if you have a 2.0L, there is another initialization connector that is translucent white (located near the green ones). if you have an 02 wrx, it connects to a blue plug. if it is 03-05's there is a solid white one that the translucent plug goes into. as donkey said, if any of these are plugged together, unplug them
__________________
your friendly, neighborhood subaru girl 06 wrx impreza: cobb stage II! // myspace; facebook hawk-eye alliance #1111 // wingl3ss @ll!ance #17 Last edited by wrxtreme06; 07-05-2009 at 08:50 AM.. Reason: added more info |
| Bookmarks |
| Thread Tools | |
| Display Modes | Rate This Thread |
