Video/Sound recording of weird sound...
Results 1 to 14 of 14
This is a discussion on Video/Sound recording of weird sound... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I can't seem to get the videos to post up but if someone that thinks they might be able to ...
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    I can't seem to get the videos to post up but if someone that thinks they might be able to help me let me know cause I can email you the videos...thanks
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Jan 2009
    Central PA
    It sounds like a whistle...the kind that has the ball in it..and when you blow it really loud...thats exactly what it sounds like...
    Subaru Guide
    Jan 2009
    Central PA
    Got it posted...
    YouTube - wrx
    Subaru Guide
    Jan 2009
    Central PA
    any ideas? I looked up so much stuff...can't decide if its waste gate flutter...exhaust leak...boost leak...I have no clue...
    Subaru Guide
    Moderator Donkey's Avatar
    Da boonies,Va
    The audio is pretty horrible.I would guess preturbo exhaust leak.Probably one of the up-pipe gaskets.Exhaust leaks can be easy to find if you have another person to help.Just start the car and let it idle.Have a person with a wet towel and gloves raise the exhaust back pressure by putting the towel over the exhaust tips.Kinda like the ol' banana in the tailpipe trip but you only want to do this for short increments at a time.Like 10-15 seconds.This should cause exhaust to blow out of the leak.You just stay up front and listen for leaks.IF nothing then move to checking the intercooler for loose connections.
    2002 FORESTER S
    1998 FORESTER S
    Jan 2009
    Central PA
    I will have to try that...see I was running a cobb ap map with 18 psi for a week and no sound...I got tuned and now I'm running 21.2 psi and I only get the sound under high boost when Its holding the high boost...I can run through the gears and I don't hear it...
    Subaru Guide
    Jan 2009
    Central PA
    I just noticed that my prodrive y pipe doesn't exactly fit onto the turbo...its ****eyed and really stretched to reach it...
    Subaru Guide
    Jan 2009
    Central PA
    oopps...didn't realize I just used a bad word...sorry!
    Subaru Guide
    Jan 2009
    Central PA
    Subaru Guide
    Jan 2009
    Central PA
    I really don't think that would cause a problem though cause its tightly clamped...but I dont know..
    Subaru Guide
    Jan 2009
    Central PA
    Well it's not boost leak....and as far as exhaust leak everything has been checked except for the turbo to up pipe section....so I don't know what to do...I really dont want to take the whole turbo off and put another gasket on...i could double up the gaskets..i still have the original one..
    The only other thing it could be is the turbo..so I guess maybe I will just start saving up for another turbo...FML....
    Subaru Guide
    Da boonies,Va
    Quote Originally Posted by lytlec View Post
    How did you test for a boost leak?Could even be your BPV is leaking from the gasket.You actually have to pressurize the the post turbo intake track with an air compressor (with an adjustable regulator) to do a proper boost leak test.
    2002 FORESTER S
    1998 FORESTER S
    Jan 2009
    Central PA
    My tuner did the boost leak test...he took the intake off and hooked it up to an air compressor...
    Subaru Guide
    Jan 2009
    Central PA
    Before I go out and buy a brand new turbo I think I am just going to drive it nice and easy for about a thousand miles and then get on it and see if the sound goes away!
    Subaru Guide
