Hesitation Problems..Please Read
Results 1 to 15 of 27
This is a discussion on Hesitation Problems..Please Read within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok fellas, here we go. I am having some serious hesitation issues with my 04 wrx with 67k miles. When ...
    Registered User Johnny V's Avatar
    Dec 2006
    Jersey Shore
    Ok fellas, here we go. I am having some serious hesitation issues with my 04 wrx with 67k miles. When I get out of vacuum and into boost, it feels like Im pulling a trailer. I hit full boost and I go nowhere. It used to only happen a lil, now it happens 90% of the time, in every gear. Sometimes it won't happen and it will pull hard and normal. Here is the history:
    Car had a TBE for about a year running stock boost..zero issues
    Car was demodded and ran full stock for about 6 months..zero issues
    A week before deciding to keep her, I feel a TINY bit of hesitation under full boost
    A week later, I put the TBE back on..problem worsens slightly
    Over the course of the past month, it has gotten bad.. to the point where sometimes a few backfires come out of the exhaust.
    No CELs at all this entire time. No smoke whatsoever. No funny smells. No oil in coolant. I have, however, noticed a different noise coming from my fuel pressure regulator. When I turn the key and the fuel pump primes, a "swoosh/light gurgle" comes from the FPR. I put my finger on it and can feel it moving in union with the noise. Now here's the thing, I can't remember if it did that before. I don't ever remember hearing it like that.
    What I've done so far:
    Changed plugs to BKR6Es
    Visually checked coilpacks and they look perfect
    Did a compression test. Results: 155, 155, 155, 160
    New vac lines to from turbo to BC to WG actuator
    Checked stock BPV, perfect..zero leaks.
    Replaced air filter
    Cleaned MAF thoroughly and cautiously
    Visually checked intercooler, looks fine.
    Removed and reinstalled intercooler, making sure that every harness, clamp, etc.. was perfect.
    Visually checked turbo inlet and BPV return hose..look fine
    Ran through 3 tankfulls of 93 Octane gas, zero issues with gas
    Checked grounding points..all tight and clean
    New battery
    Looked at the FPR..no leaks..no smell of gasoline, clean connections
    What I haven't done/suspect:
    I havent done a pressure test
    I havent done a leakdown test (really dont think I need to)
    I havent checked the injectors (they are stock and have never been touched)
    I havent checked the fuel pump (my biggest suspect right now)
    Now, I know some may say I need a tune, but I ran like this for a long time without issues. I do need a tune and will be getting one soon, but I need to resolve this issue before then. This problem only happens when I enter boost. At 0psi and vacuum, the car is perfect. In second gear I can get it to break out of hesitating by getting off the gas and back on a lil, then it seems to push past the hesitation and pulls free and hard. It idles like a charm and when it doesn't hesitate, it runs super smooth. If i can think of anything else, Ill post up right away.
    -2004 San Remo Red WRX Sedan-
    Blobeye Syndicate #24
    "Pain of Discipline or Pain of Regret..take your pick." ~ Notre Dame
    Jun 2009
    Quote Originally Posted by Johnny V View Post
    Replaced air filter
    New battery
    Same issues with me!!!
    Registered User wrxlaunch's Avatar
    Apr 2008
    DC,MD,VA
    fuel pump going bad or dirty injuectors maybe???
    VF-43 Bugeye: OPEN SOURCE tune... 121xxx miles
    13.1@105... Lazy launch 1.9 60'
    285whp and 300WTQ.
    Registered User Spencer3636's Avatar
    Apr 2009
    No-Town
    or a simple ECU reset, you really never know. I would give it a shot, it only takes 30 seconds.
    Carpe Diem!
    My 03 Bugeye is cooler than your mom
    Bugeye Mafia #222
    Dec 2006
    Jersey Shore
    Quote Originally Posted by Spencer3636 View Post
    I did that too, twice actually. forgot to list it, lol.
    Registered User ZACK777's Avatar
    Sep 2007
    Cincinnati, OH
    I would replace the fuel filter, and also if the car is jerking or missing at all when it hesitates check to make sure the crank position sensor is not faulty (<-- fixed my hesitation missing problem)
    GL
    2004 PSM WRX VF39'd and loving it. SOLD
    2002 PSM WRX VF29'd, work in progress...
    2008 VW R32 #234/5000
    2000 Camaro SS H/C/I/E, loud.. fast.. yuup.
    2003 Silverado 6.0 project
    blObeye SYNDICATE #88
    "In art, as in love, instinct is enough."
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Fuel filter, crap in the tank, or a screwed up linkage to your waste-gate. Check this first. If the linkage is loose or screwy, you wouldn't know it without seeing it.
    Fuel filter is the easiest.
    If crud is in your tank, replacing the fuel pump may resolve it.
    Did you check MAF sensor connections and made sure the MAF is clean? I seem to remember something about cleaning the EGR when power loss occurs too....anyone else remember this?
    The good ole oxygen-fuel-spark triangle and troubleshooting it...dontchajustloveit
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Dec 2006
    Jersey Shore
    Update: Replaced fuel filter. No change.
    Moderator Donkey's Avatar
    Da boonies,Va
    For $20 you can buy a VAG-COM cable off ebay and use Romraider to datalog or use as a scanner if you have a laptop.
    2002 FORESTER S
    1998 FORESTER S
    Dec 2006
    Jersey Shore
    im going to try and log the car tonite with my tactrix cable. Ill report back.
    Da boonies,Va
    If you had a Tactrix cable why didn't you log it in the first place?That would have been the first thing I would have done before swapping parts out.......................
    2002 FORESTER S
    1998 FORESTER S
    Dec 2006
    Jersey Shore
    Changed the fuel pump..still doing it.
    Update: checked the FPR, no leaks, seems fine. Haven't gotten a chance to log it yet, but a rattling has become quite apparent. From ear-analysis, it seems to be coming from the passenger side of the engine. I know it's not my exhaust. It's either a heat shield or the cat in the uppipe rattling around... Tomorrow i will begin taking the uppipe out to see what it looks like in there, and then gutting it out. Good thing I have a VF34 on the way.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    I'll put money on a piece of catalytic converter blowing into the turbo.
    I'll put large lump sums of money on it.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Registered User Kelley725's Avatar
    Jun 2009
    Maryland
    My mechanic told me there are 2 cat's on my 02 WRX.He suggested taking out the cat at the turbo to prevent just that from happening. I have been having trouble with hesitation and jerking too. He also suggested switching the cold air intake back to stock. Any truth to all that helping? I'm a newbie and have had trouble posting my own thread on these issues.
    Jul 2003
    PA
    Well, you've determined it is not a fuel problem, not a spark problem, so it has to be an air flow problem. In this case, sounds like exhaust flow, so yeah...lookin like the cat.
