really need some help plz
Results 1 to 8 of 8
This is a discussion on really need some help plz within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i drive an 06 wrx so im driving down the road the other day and my check engine comes on ...
    Jun 2009
    austin
    i drive an 06 wrx so im driving down the road the other day and my check engine comes on then the car bogs down. and no matter how much gas i give it i cant get it over 2000 rpms i ran a diagnostic on it and the code came up p607 if i disconnect the battery cable and reconnect it the car will run for a little bit before it happens again ive check every thing but cant figure it out. anyone have an idea
    May 2007
    orlando flawduh
    do you mean P0607?
    thats the "control module performance" CEL
    as per nasioc: it's a wiring problem between the pedal and ECU or the ground/power to the pedal or ECU
    if you look under your dash on your drivers side, there should be 2 green connector plugs. go check and see if those are plugged in together. if they are, disconnect them & see if you still have a problem
    if not... we're gonna have to wait for someone else to chime in
    desiree
    Jun 2009
    austin
    oh ha ha yeah i did mean p0607 but yeah those plugs are already disconnected. do you think that it could have some thing to do with my ecu
    May 2007
    orlando flawduh
    well, those are "test connector" plugs that you use to flash your ECU to different maps with an accessport.
    unless you are changing maps they should not be connected at all.. so
    if they're already disconnected, i dont think thats the problem.
    desiree
    Jun 2009
    austin
    do you think it could be a faulty wire running to my ecm
    Jun 2009
    austin
    do you know where the ecu is located
    Nov 2008
    scotland , edinburgh
    underneath the passenger footwell behind metal plate
    Aug 2008
    Kennett Square, Pennsylvania
    before you go digging around..it might be worth it to clear the code and see if it comes back...On the thousands of Subarus Ive worked on over the years I have NEVER seen this code come up once...
