battery trouble?
Results 1 to 6 of 6
This is a discussion on battery trouble? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My WRX refuses to turn over when i start the car. I'm thinking it's a battery problem, however I'm not ...
    Jun 2009
    battery trouble?
    My WRX refuses to turn over when i start the car. I'm thinking it's a battery problem, however I'm not too sure. How can I go about troubleshooting it? If it is in fact the battery, can I use the battery can I use the battery out of my spare 1996 Ford Escort?
    Aug 2008
    Kennett Square, Pennsylvania
    What year is the WRX? How many miles? Has the car been sitting? Any recent work performed? Have you tried jumping the car? You might be able to use the battery out of the escort...take a look at the CCA (cold cranking amps) on the battery in the escort and the battery in the WRX if they are around the same number You should be able to give it a try...Also is the battery in the escort side post or top post? So is the car cranking or just clicking when you turn the key?
    Jun 2009
    The car has about 93,000 miles and was sitting around while I was at college so that's why I figured it was the battery. I can jump the car to start it. The car is also cranking when I turn the key.
    Aug 2008
    Well if the starts when you jump it..yeah I'm going to say its the battery (from the info. you've given)...You can usually pick up a half decent cheap replacement at Walmart...
    Jun 2009
    ended up being the battery...easy fix...thanks for the help
    Aug 2008
    no prob. man..glad it was something simple...
