the Turbo is not boosting..any help ?
Results 1 to 15 of 20
This is a discussion on the Turbo is not boosting..any help ? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hello guys ,, first of all excuse me for my bad english i drive a legacy 2002 with a WRX ...
    Jun 2009
    hello guys ,,
    i drive a legacy 2002 with a WRX 2L engine..few weeks ago i got some problems with the turbo its not boosting as well .. i replaced the west gate with a new one but still the same problem, i borrow my friend turbo to test it on my car but i got the same i checked every thing with expert friend but nothing
    i went to subaru expert mechanical and he told me that my engine compression is low .. so i replaced the hole engine with other used one and we used my old turbo but i still have the same problem!! any help guys ?
    Jul 2004
    Seattle, WA
    Did you do any modifications shortly before you had the problems boosting?
    Did you check the compression of the new engine?
    If the compression of the new engine is good, then you either have a boost leak or a problem with the turbo.
    Jun 2009
    Quote Originally Posted by jeremy96gase View Post
    thx for your fast replay jeremy96gase
    no i did not any new modifications..the compression of the new engine is perfect..what is the boost leak ?
    Aug 2008
    Kennett Square, Pennsylvania
    A boost leak is when you have an opening in the intake track from the compressor outlet of the Turbo to the throttle body letting, exactly what it says "boost leak"...thus not hitting target boost when desired..As mentioned I would go over all clamps and vacuum lines and make sure they are tight/connected properly and arent damaged. What parts did you use off of the old engine besides the turbo? How many miles are on the "new" engine? Did you see/hear about the vehicle the "new" engine was removed from? Im assuming you've inspected your turbo for shaft play/ seal leakage etc etc ??? Do you have any idle problems or any other driveability problems? Do you have a boost gauge or any other way of monitoring boost?
    Jul 2004
    Seattle, WA
    Boost leak test instructions
    Just completed the DIY "find your leak" tool. - NASIOC
    This one's not for a Subaru, but has loads of tasty information
    BOOST LEAK GUIDE
    Also any Subaru dealer should be able to perform this test.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    how old is the turbo? how much boost is ran through it? etc... it may have fried bearings as well... not common, but a possibility if there's any oil starvation problems.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Jun 2009
    EvoEatr
    i did not use any part from the old engine .. just the turbo..and the "new" engine imported from japan and i have no idea How many miles are on .. i dont have any idle problems or any other driveability problems, and about the boost leak i tested all lines but i will do other test by using air compressor to see if there is any leak.
    i have boost gauge, its not famous brand but its working smoothly
    i have replaced this parts befor changing the engine :
    air mass ,engine computer , intercooler , turbo
    Aug 2008
    so if your 100% sure your boost gauge is accurate what max boost are hitting? I'm assuming the entire power train is stock?
    Jun 2009
    now the gauge hitting 0.5 max
    befor it can reach 1.0
    Aug 2008
    yeah as mentioned first step I would do is a boost leak test...let us know what you come up with...
    Oct 2005
    Late Devonian
    It sounds like you are running on wastegate spring pressure only. Suspect your boost control solenoid is stuck closed.
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    If you did an engine swap, and the ECU (computer) went with the swap, did you have to do a wiring harness swap too?
    This may be silly, but have you checked all of your fuses?
    If you have changed out engines, what parts did you keep from the old engine?
    It sure sounds like a vacuum or boost issue. I'd be looking closely at the solenoid, the vacuum lines, or the machanical wastegate linkage.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Jun 2009
    guys my problem is fixed now .. and here what i did to fix it
    first thing i return the new engine and installed my old engine with all its stuff again .. then perform a leak test so i found 3 boost leak points , i changed all vacuum lines and that device near air mass which one vacuume line connected to it
    and my car performance become better than before
    am really amazed what boost leak can do to the engine performance..well thank you guys for your help
    now am sure you guys know about subaru more than some subaru expert technicals
    Jul 2003
    PA
    Glad the site could help
    Nov 2008
    scotland , edinburgh
    sounds like ur missing the restrictor pill between the compressor housing and the tee piece inside that black hose
    not sure about o2 models like but u only get wastgate pressur (0.5 bar ) when this restrictor is missing , it is a small brass bullet shaped thing inside the hose coming off the turbo its self before the tee piece it should have a small hole through it
