new owner with a question"cylinder one misfire"
Results 1 to 6 of 6
This is a discussion on new owner with a question"cylinder one misfire" within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Well I have had it for two months the check engine light cam on so my friend plugged it in ...
    Jun 2009
    Tehachapi C.A.
    Well I have had it for two months the check engine light cam on so my friend plugged it in and it said cylinder one misfire. I replaced the plugs checked cylinder one with a compression tester and I had 125 psi The wires dont seem to bad. Also I am retarded to the turbo world and thought i had a recirculating hks bov and its not. So do you think I hurt anything? And maybe have a stockie for sale?? Sorry if I sound dumb I have been a N.A. rotary guy since I got into cars.... Thanks for anyones input....
    Oct 2005
    Late Devonian
    Quote Originally Posted by WrxLove02 View Post
    I'd take the BOV off too but it probably isn't related.
    It could just be bad gas. I have also heard of problems with the crank position sensor. For '02 someone mentioned a reflash is available from the dealer for misfire issues as well.
    I'm going to move this to troubleshooting, hopefully you will get more input there.
    Jun 2009
    Tehachapi C.A.
    Thanks for your help anyone. Yeah I am trying to get a stock bov right now. and you just take it to the dealer and get it flashed??
    Oct 2005
    Late Devonian
    I would call them first.
    Any chance you have a lightened flywheel or pulley?
    There are a ton of things that could be going on though - plugs, fuel pressure, dirty injectors, dirty MAF (do you have a stock intake?), vacuum leak.
    Registered User 06WRXturbo's Avatar
    Nov 2006
    VA
    Try swapping #1 and #3 coil packs and see if the misfire follows the coilpack. Free and easy way to eliminate one of the many possibilies. Did your friend clear the code? Did it come back?
    Just in case you dont know the cylinder #'s...
    3 4
    1 2
    front of car
    Jun 2009
    Tehachapi C.A.
    Yeah we cleared it and it came back. Than I put cleaner in it and it went away so I think I might need to change my injectors
