Results 1 to 5 of 5
This is a discussion on Help!!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 04 wrx sti, it was raced this past weekend. it was working fine until yesterday. The clutch ...
    Jun 2009
    LAS VEGAS
    Help!!!!
    I have an 04 wrx sti, it was raced this past weekend. it was working fine until yesterday. The clutch goes to the floor but i can put the gears in smoothly. It is only going 25mph. what might be wrong with it?
    Jul 2004
    Seattle, WA
    Quote Originally Posted by IZA380 View Post
    You need a new clutch.
    Edit: just to verify what's going on.
    If you're in gear, and you floor the gas peddle the RPM's go up, but the speedometer doesn't... then you need a new clutch.
    Jun 2009
    Richmond, VA
    Sounds like you burned it up racing (the clutch)....did you notice a burning type smell at anytime between your runs? You'll know it if it's a burnt clutch smell...different than burnt rubber from tires
    -Dave
    2004 PSM WRX Wagon
    Stage 2
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    if you didn't completely fry the clutch, it's possible to recover
    May 2009
    the same thing happened to one of my friends Jetta, it ended up being the fly wheel, but i think u need to take off the clutch to get to that anyways, so if that is the case u might replace both at the same time.
