Results 1 to 11 of 11
This is a discussion on please don't tell me my wrx is falling apart?!? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've had my 2002 Impreza WRX for about two years and now I'm starting to run into problems with it. ...
    Jun 2009
    I've had my 2002 Impreza WRX for about two years and now I'm starting to run into problems with it. My WRX now does not start immediately, it takes a couple times to start...I guess the starter has to warm up. But, when it starts my ABS, Brake, and battery light goes on. I am able to drive a car however it obviously sounds like it is not running right. My powersteering no longer works and between gear shifting my RPMs and MPH drop to 0 on the dashboard. I was wondering if anyone could help me and try to figure out what might be going wrong with my car. Thanks
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    I'm sorry, it's falling apart.
    Registered User Spencer3636's Avatar
    Apr 2009
    No-Town
    That sounds mostly electrical related, I could be wrong but I'm just saying.
    How many miles on the car? Any mods?
    Carpe Diem!
    My 03 Bugeye is cooler than your mom
    Bugeye Mafia #222
    Have a shop check the battery, the leads, and the alternator.
    Registered User STi Nova's Avatar
    Oct 2003
    Maplewood, NJ
    Most def have it checked out. Sorry to hear that.
    It's working... it's working!!!!
    02 WRB WRX Wagon (R.I.P)
    Project 240 DIY: 93 240sx : Done
    2004 WRX Wagon
    Jun 2009
    Quote Originally Posted by Spencer3636 View Post
    Around 93K miles...just an intake, exhaust, and blow off valve
    Apr 2009
    No-Town
    Quote Originally Posted by metsman7 View Post
    I'm sticking with electrical. As SD_GR said, have a shop check the battery, leads and alternator.
    I would also recommend that you find the original BPV and take off that blow off, it is doing more harm than good and has no performance advantages for your car.
    Check your electrical, remove BOV, reset ECU. That is a pretty good starting checklist of things to do
    Carpe Diem!
    Bugeye Mafia #222
    Oct 2005
    Late Devonian
    what are the cel codes?
    Jul 2004
    Seattle, WA
    It sounds like the Negative cable going from the battery to the body isn't making good contact.
    Or the battery needs to be changed out.
    +1 ditch the BOV.
    Do your lights also dim at night when you step on the brakes?
    Jun 2009
    Quote Originally Posted by jeremy96gase View Post
    +1 ditch the BOV.
    yeah the lights dim sometimes when i first start the car...i think it's a bad wire as well because sometimes my ignition won't start right away and soemtimes my radio will turn off
    Jul 2004
    Seattle, WA
    I think it sounds like a bad connection to the battery or the battery it self.
    How old is the battery, is it original?
    As for the connections, just open the engine bay, and start looking around
