Think I made an oops!
Results 1 to 5 of 5
This is a discussion on Think I made an oops! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So about a month ago i swapped out my uppipe with a catless one and replaced my exhaust with one ...
    Registered User CJ05's Avatar
    Apr 2008
    North Juarez Mexico (aka El Paso TX)
    So about a month ago i swapped out my uppipe with a catless one and replaced my exhaust with one from an STi. During the process i completely removed the turbo (kinda had to to get the uppipe out) anyways, i got everything put back in and forgot to reclamp the oil return line that runs directly underneath the turbo. The metal line is completely seated inside the rubber hose and it is clamped on the bottom but not on the top. Could this be an issue or should i be good to go? Reason i am asking is that my oil was low when i checked it this morning.
    Bugeye Mafia #231 - 2002 WRB - sold Dec 31, 2009
    -Stink-Eye Mob-#173 - 2008 SWP - Returned to TD04 Stage 2 in Jan 2012
    Frmr Blobeye Syndicate #173 - 2005 CGM -sold Sept 15, 2008. I miss my STi
    Proud owner of 99 RS coupe with EJ205 engine and tranny swap.
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    Your not losing oil from it, but you need to properly clamp all lines. Go ahead and recheck your oil level after 5-10 mins of run time. If it's below the low mark, add some oil.
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Aug 2008
    Kennett Square, Pennsylvania
    I would def. go back and double check that line..just to make sure its not leaking...OH FWIW...next time you put an up pipe on one of these 2.5 or 2.0 Turbo cars...you can install the up pipe without pulling the Turbo...Just undo the two 14mm's for the motor mounts and the two 14mm for the dogbone and jack the motor up a bit...I think its a hell of alot easier...
    Registered User 2:43AM's Avatar
    Sep 2008
    NWI
    Just one nut, on the passenger side mount, and jack up 2 inches. Cake walk.
    Apr 2008
    I checked it and it's not leaking oil...plus when i checked my oil later that evening after adding about 3/4 of a quart my oil level is not high. Both times the car was checked hot so there shouldn't be any discrepancy between the two readings.
