Well either you didn't rebuild it correctly or you maybe you didn't prime it correctly.Did you prime/bleed it to the factory specs?
This is a discussion on Power Steering Inop within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Power steering quick working all at once. Pump was leaking a little so I rebuilt it with Subaru OEM kit, ...
Power steering quick working all at once. Pump was leaking a little so I rebuilt it with Subaru OEM kit, all internals look great. Power steering still inop. Any suggestions for trouble shooting and repair? Thanks!
The rebuild was very easy. I pre-primed then bled the pump. No leaks at all now. I'm thinking it may be in either the electronic function for on/off or a solenoid valve but not sure how to trouble shoot that circuit. Any help is appreciated. Thanks!![]()
