whats wrong with this thing!!!
Results 1 to 7 of 7
This is a discussion on whats wrong with this thing!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey im brandon and this thread is on behalf of my friend cus hes too ''cool'' to sign up to ...
    May 2009
    hey im brandon and this thread is on behalf of my friend cus hes too ''cool'' to sign up to a forum i guess haha. ne way. its an 04 wrx w/ a sti short block, wrx heads, brian crower valve springs and 272 cams, stock wrx injectors, walbro 255 pump, full turbo back exhaust, ebay turbo inlet hose, short ram, factory top mount, factory bov, f1 flywheel and some off brand stage 2 clutch. we put the motor in about 5k miles ago, and when we were breaking it in it ran really good with a break in tune, and after he broke it in he beat the **** out of it, and i mean beat!! then after 2k miles the car would chug and miss everytime he would get close to boost, 1-3 inhg and even worse on boost. we checked the codes and sure enough all 4 cyl are missing. we cleared it and it came back within 5 min. so we go to the tune place and get another map put on. still doesnt solve the problem. then he decides to get a dyno tune. possibly the most dissapointing thing ive ever seen...... 37 hp at 4k rpm!!!!! the afr was all over the place when he hit boost. we have checked almost everything we can. has anyone had a similar problem to this? ive done a compression test on it and mad sure no vacuum lines were disconnected or loose. right now i think its a fueling issue or unless the ckp or cmp is telling all 4 plugs to miss. im out of ideas. someone please help
    Oct 2005
    Late Devonian
    clean MAF
    replace Fuel Filter, check pressure
    clean injectors
    check sparkplugs
    clean grounds on manifold
    Registered User ZACK777's Avatar
    Sep 2007
    Cincinnati, OH
    Check the Crank Position Sensor. I had a similar missing problem over a year ago and it turned out to be a faulty sensor. GL
    2004 PSM WRX VF39'd and loving it. SOLD
    2002 PSM WRX VF29'd, work in progress...
    2008 VW R32 #234/5000
    2000 Camaro SS H/C/I/E, loud.. fast.. yuup.
    2003 Silverado 6.0 project
    blObeye SYNDICATE #88
    "In art, as in love, instinct is enough."
    May 2009
    ive cleaned the maf, replaced the fuel filter, checkd and re-gaped plugs, and cleaned all the grounds. when you ohmed the ckp what was the value you got?
    Sep 2007
    Cincinnati, OH
    Quote Originally Posted by innes887 View Post
    When I took my car to the shop they had no idea what was wrong with it.
    That night I went over EVERYTHING under the hood and found that the Crank Position Sensor plug was cracked and would not stay on securely, so I replaced it and have yet to have any missing or hesitation problems.
    Moderator Donkey's Avatar
    Da boonies,Va
    Unless you have a way to datalog the car diagnosing this over the internet is not going to be quick or efficient at any means...........could be tons of things.Check compression,do a leak down test,check cam timing,boost leak test,vacuum leak test...........ect.The ability to datalog the car makes it 10x easier to find out whats going on.
    2002 FORESTER S
    1998 FORESTER S
    May 2009
    yeah datalog would be alot easier but i dont hav access to all those tools. we did a compression test a few days ago and it checked out fine. a variance of 5 psi across all cylinders and the avg was 145. i just ohmd the ckp and it gave me 2.3k ohms. does anyone know the spec?
