Brake caliper piston seal replacement ?
Results 1 to 5 of 5
This is a discussion on Brake caliper piston seal replacement ? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi I fly a WRX wagon 2006 I was changing rims the other day and noticed that the inner side ...
    Registered User Ivg|'s Avatar
    May 2008
    Iceland
    Hi
    and noticed that the inner side of the caliper does not go back so the pad is pretty much done on that part. the outer part works as it should and the pad there is fine.
    Its a 4piston caliper.
    My guess was that the seal had broke and dirt came in between. Preventing the piston to roll back.
    So I went to get a seal replacement kit and new pads.
    Any advices / Hints before I go and do something stupid that could ruin the caliper / pistons / ?
    WRX Wagon '06
    Registered User wrxloaf08's Avatar
    Oct 2008
    Fayetteville NC
    they're just pushed out that way by hydraulics - grab a small vice and push them back in.. not a big deal?
    08 WRX Sedan
    the WRX is back! 340whp 366 tq @22psi
    May 2008
    Iceland
    Since I was changing the rear pads I decided to take a look at the front aswell.
    I took the pads out the outer one was as easy as opening a can of Red Bull but pressing the pistons back on the inner was way harder and I only managed to get them just as far as I needed to yank the ruined pad out.
    And can't get the piston any further back.
    So I think I am gonna go through on this and tear the whole thing apart when I get more time.
    WRX Wagon '06
    Jul 2008
    If you get a pair of Vise grip C clamp tools, nothing smaller than 6 inches, you cna very quickly push the pistons back into the calipers. The trick is to squeeze them simultaneously so your compression of one piston doesn't just push out the other.
    Oct 2008
    Fayetteville NC
    Quote Originally Posted by specialev View Post
    yup, just 2 vices to push both pistons in at same time..
    08 WRX Sedan
