Bogging/no power/jerking
Page 1 of 3 123 LastLast
Results 1 to 15 of 42
This is a discussion on Bogging/no power/jerking within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello i have a 2002 wrx with 102k on it. Recently i put a downipe on it but i put ...
    Registered User wrxwagon2's Avatar
    Feb 2009
    allentown,pennsylvania
    Hello i have a 2002 wrx with 102k on it. Recently i put a downipe on it but i put the stock one back on because i thought it might be the problem. I reset my computer so the check engine light isnt on yet but by car at idle when i hit the gas it studders then revs. also it jerks really bad at low rpms and has no power around 5k and really 50% power all around the rpm range. So im gonna get it scanned this weekend if the check engine light returns but i was wondering if anyone had any ideas. Thanks
    2004 WRX (currently driving)
    2000 Audi S4 APR tuned (sold)
    2002 WRX wagon ( sold )
    1988 Thunderbird Turbocoupe
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by wrxwagon2 View Post
    First... do you have a boost gauge?
    Second... did you do the O2 sensor fix like you're supposed to?
    Third... do you have EM?
    Fourth... do you have the stock up-pipe?
    I have a bad feeling this could be the cat in the up-pipe fragmenting. If you don't have a CEL, but you have 50% power in the full range.. then the cat could've fragmented into your turbo. That's why I want to know if you have a boost gauge.
    Just to be sure.. the Cruise Control light isn't blinking, is it?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Oct 2005
    Late Devonian
    Also kind of sounds like a fuel filter.
    Nov 2006
    Denver Metro Area
    True.. it is at 100k+ miles...
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Feb 2009
    ok so i just got back from autozone and they scanned it and the code P0171 came up which is either a faulty MAF sensor, vacum leak, low fuel pressure, or a plugged injector/ cylinder misfire. So what i did so far was clean the MAF and put injector cleaner in. I have a feeling it might be he fuel filter too. Idk what to buy first though because a new MAF is $180 and if i buy that and thats not the problem i just wasted 180 dollars.
    Feb 2009
    Also i was wondering if after i do all these things to try to get the CEL off do i have to reset the ecu and drive it and see if it comes back on? or do i just drive it with the light on and see if it goes off? thanks
    Registered User Pactin's Avatar
    Nov 2007
    California
    it won't turn off til you fix the problem. once u do, just reset.
    --Justin
    Hawk-Eye Alliance #128
    Oct 2005
    Late Devonian
    Do the filter first, or both. The filter is a no brainer, it is good maintenance and it is cheap.
    Reset and see if it comes back.
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    Can of Seafoam works wonders for the filter and injectors. Just a thought.
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Feb 2009
    put a new fuel filter on and it smoothed out the idle but its still cuts some power out around 5 thousand rpm, thinking i need a new MAF..
    Registered User wrx0131's Avatar
    Jul 2007
    Yonkers, NY
    They usually go hand in hand. I had the same problem; I replaced my fuel filter and it slightly fixed the problem. Then my car started running lean and i destroyed one of my pistons. Turned out to be a bad MAF sensor. Get that replaced ASAP.
    Bugeye Mafia #213
    Kevin
    2002 Midnight Black Pearl WRX (Traded In!)
    2012 Ice Silver Metallic STi Sedan
    Oct 2005
    Late Devonian
    Reset your ECU?
    Oct 2005
    Late Devonian
    Quote Originally Posted by wrx0131 View Post
    That is a bummer. Bad or dirty MAFs usually go with oil based air filters. I can't figure how the MAF failing would be related to the fuel filter in any way though.
    Jul 2007
    Yonkers, NY
    Sorry i meant to say that they both have similar symptoms, so sometimes it could be either/or.
    Bugeye Mafia #213
    Kevin
    Oct 2005
    Late Devonian
    Ah, makes sense.
