Horrible clutch noise (video, and searched)
Results 1 to 15 of 19
This is a discussion on Horrible clutch noise (video, and searched) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Iím sorry if this is been asked before, but I searched and didnít find anything. So I recently washed my ...
    Jun 2008
    Scottsdale, AZ
    Iím sorry if this is been asked before, but I searched and didnít find anything. So I recently washed my engine with a pressure washer and some engine degreaser called engine brite. After which, this horrible clutch noise came about and I shriek every time I hear it. Now Iíve heard of peoples clutches squeaking after a rain or washing their cars but this has been going on for two days now, and not only does it sound horrible but it feels like crap too. Itís not smooth, it sort of has the feeling of stepping on snow and compacting it. The engine still smells from the degreaser so the only thing I can think of is that there is a rubber boot type deal around the cable or something and there is some residue on it (kind of like chewing on a balloon haha)? Or something else has gone very wrong. I donít know much about clutches or the transmission so Iím at a loss. Just a bit of background information itís an 03 wrx with 88k miles on it and from what I know is stock. I also donít drive very aggressively, so itís not like Iím dumping it everywhere. So watch the video and any help is greatly appreciated; because this noise is just horrible .
    Also, I am in need of some coolant soon. Do I have to use the Genuine Subaru coolant? Itís ridiculously expensive.
    VIDEO: horrible clutch noise on Flickr - Photo Sharing!
    Registered User ZACK777's Avatar
    Sep 2007
    Cincinnati, OH
    This may have nothing to do with your problem but on my pickup the clutch made a very similar sound before going out. Hope its not your case.
    2004 PSM WRX VF39'd and loving it.
    1979 Camaro Z28 383 stroker
    1993 Silverado 6.5 TD "Old Smokey"
    1974 Honda CB750 cafe racer project
    blObeye SYNDICATE #88
    "In art, as in love, instinct is enough."
    Jun 2008
    Scottsdale, AZ
    Quote Originally Posted by ZACK777 View Post
    Well how did it drive with it making that sound?
    Cause it pretty much drives the same except for a tiny bit of bog from a dead stop, although that just may be me making it do that.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    My clutch didn't squeak like that when it was going out.
    Especially since the car isn't on when he's doing it.
    I think he might just need to grease up the clutch pedal.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Sep 2007
    Cincinnati, OH
    Quote Originally Posted by l2yan View Post
    Well it progressively got harder to put into gear and got to a point you had to turn it off to put it into 1st or reverse. The shop said it looked like a grenade went off in there to cause that much damage, pieces of springs and **** everywhere.
    I don't think his is going out, and would try what you said, grease her up. The video just reminded me of the sound my truck made before going out.
    Jun 2008
    Scottsdale, AZ
    Not the sound yours makes after the rain huh?
    Nov 2006
    Denver Metro Area
    More than likely there is water sitting in there. Rub a bit of lithium grease on the shaft that goes through the firewall. It'll help displace the water, and it'll help get rid of the squeak.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Jun 2008
    Scottsdale, AZ
    Firewall? *embarrassed*
    Nov 2006
    Denver Metro Area
    look at your clutch. See the post that goes through the footwell?
    The piece of metal that prevents an engine fire from spreading to the cabin is called a firewall. It's a divider between the engine compartment and cabin.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Jun 2008
    Scottsdale, AZ
    Thats what I figured but I just wanted to double check. Well that will have to be tomorrows project.
    Now, anyone know anything about that coolant?
    Registered User Sooby-Doo's Avatar
    Dec 2005
    Tampa
    I apologize but no idea on the clutch. Kevin is more than likely correct though. A little Lithium grease goes a long way.
    As far as coolant though, I use Redline Water Wetter with distilled water. I've logged 20+ degree temp drops over 50/50 (this is in FL during mid summer 98+ degrees).
    And no, IMO, you do not have to use Genuine Subaru Coolant. Some people are nutty about only using Subaru Genuine whatever so take everyone's opinions as just that and then formulate your own GL
    S&R Built 2.5/2.0 '03 Hybrid w/ PE1818
    Scott Siegel Tuned 308whp/320wtq
    Vogtland Club Spec Springs on KYB AGX's
    ******* I BOOST, therefore I AM! *******
    Jun 2008
    Scottsdale, AZ
    Quote Originally Posted by Sooby-Doo View Post
    I think I'm just gonna use it for now seeing as I have other **** that I need to deal with on this car, and I'd rather just play it safe. Thanks though.
    Nov 2006
    Denver Metro Area
    it's not a bad idea.
    Find out first if the subaru stuff is 50/50, or 100% coolant. If it's 50/50, there is no reason why you should be paying so much for premixed. Premixing is a scam. They only way premix is a good idea, is if you are a touch low, and you have to add just a bit. Then it's just convenient.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Jun 2008
    Scottsdale, AZ
    Yea that poped in my head after I called them and asked for the price earlier. Cause I certainly wouldnt pay $25 for premixed. I'll call and ask tomorrow and see since I cant get it today anyways.
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    My clutch sometimes creaks as well when I push it in, it doesn't do it often...I posted about this awhile ago...it's still working fine! It seems to only do it on days when its wet outside...
