What is "it?" The A/C? The blower motor?
This implies "it" above is the blower motor.i know the air is getting cold because i can have it on and drive with the vents on and can feel the air a little.
The blower switch or blower motor.anyone have any clue what could cause this issue?
A/C Compressor problems...if its the Blower is it a hard install?
I am assuming you do not hear the blower motor spinning when you do not get air flow. If you do hear the motor spinning, start by removing the glovebox and checking if the filter is clogged or if you do not have a filter, if there is an obstruction. If you hear no fan noise, see above but in your case it could be a loose harness clip since you hear nothing at all, or a switch problem.
Priceless. Consider a used unit from a wrecked car (plenty of wrecked WRXs...). Or contact subaruparts.com or another online vendor for a new unit and pricing.and price??
LinkBack URL
About LinkBacks
