I know others have had several bolts fall out of their power window motor assembly but my problem is particularly annoying. Two bolts fell out but one of them somehow bent the metal around the hole and the metal is now sticking out so the short bolt can't even find the thread. I'm also concerned that the thread may be damaged but I can't really tell. The holes seemingly won't even line up correctly. Do you guys know what size the bolts are? Has anyone even seen this happen the way it did to me before? I was going to try to get a body shop to flatten it out and see if I can get the stinkin' bolt in.
