Rotor replacement help
Results 1 to 4 of 4
This is a discussion on Rotor replacement help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Anyone know what kinda bolts ( the 2 in the middle of the rotor ) do I need back off ...
    Oct 2008
    Red face Rotor replacement help
    do I need back off the rotors on a 2004 wrx
    thanks,
    Registered User T.J.'s Avatar
    Oct 2002
    on a boat...
    To remove the rotors you just take off the wheel and the two bolts holding the caliper in place, then hang the caliper out of the way and pull off the rotor, right?
    200,000 mile club.
    Old Irish adage: "Do not resent growing old. Many are denied the privilege."
    Aug 2008
    Kennett Square, Pennsylvania
    correct...If the rotor wont come off like its rusted on there and your replacing the rotors...smash away with a hammer....Before you remove the caliper though and if your only replacing rotors not pads...I would stick a screwdriver through the inspection eye of the caliper and pry on the pads to push the caliper piston back in a little bit otherwise you will never get the caliper over the new rotor...
    The car itself can provide the screws you need. The two foremost screws on the subframe (the "U" shaped metal piece) usually fit correctly. These are sometimes covered by the plastic undertray.
