Results 1 to 5 of 5
This is a discussion on Front seat seatback spring bracket broke - ideas? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was minding my own business, driving down the street and I heard a SPROING. It felt like it was ...
    Registered User WrecksWruthor's Avatar
    Feb 2008
    VA
    I was minding my own business, driving down the street and I heard a SPROING. It felt like it was in the seat. I hit the back of the seat with my hand to feel around for the springs, and sure enough one of them was flapping loose.
    I unzipped the right side of the seat cover, and one of the mounting brackets for the springs had snapped in half.
    See this pic of the bottom spring, which isn't broken. You can see the other spring above it out of place.
    The bracket itself snapped in half, as you can see here.
    My question is whether you all have any ideas to fix it. I could get somebody to weld the broken half of the bracket back on. Otherwise, I can't see any way to fix just that piece other than grind off the old bracket, find a new bracket, weld the whole new bracket in place, and reassemble like new. All that requires a lot of labor that I don't have the tools for. The other option is pick up a junkyard seat and rebuild or replace the seat.
    This is a pretty bizarre repair, but I'm open to any (cheap) suggestions.
    Thanks!
    Feb 2008
    VA
    Problem solved...for now
    Talked to a guy who recommended a hose clamp to put the spring back on. So far, so good. The fix was cheap and easy, now we'll see if it holds and for how long.
    Jul 2004
    Seattle, WA
    Thanks for posting this!
    I have a similar issue with my couch, and will have to give that a try
    Registered User Organ Donor's Avatar
    May 2009
    Federal Way, WA
    If it works, it works. If not, you can always JB Weld that crap together.
    "A man can be with any woman, as long as he is not in love with her." -- Lord Henry
    "Patriotism is a virtue of the vicious."-- Oscar Wilde
    Feb 2008
    VA
    Quote Originally Posted by jeremy96gase View Post
    On your couch, maybe you could look for a mounting point for a U-bolt. It would be ever so slightly less ghetto. Then again, in both cases the fix is completely hidden so who cares.
