exhaust meaning a catback? turbo back?
This is a discussion on multiple component engine failure within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; well this story begins May 9 at 1am, i was driving to a mexican food restaurant on the freeway while ...
well this story begins May 9 at 1am, i was driving to a mexican food restaurant on the freeway while going around 80mph. all of a sudden my 05 wrx makes a whipping type sound and proceeds to die on me. i pull over and have the car towed to my parents house with no idea what happened. the engine would no crank over. so later that saturday i tow the car to kearney mesa subaru to get it checked out. i tell them what i heard and the service adviser says that it could possibly be a bent crank. he then said that the car is within the 60,000 mile warranty (59,908 miles). i was super happy i thought it was beyond the factory warranty. so they say they are busy and wouldn't be able to check out the car till monday. so i say ok. come monday i call and try to find out if there was any news and the service adviser tells me to bring in all the maintenance records i have. so bring all the records for the year and a half i've owned the car and am told that they should have an answer by friday. so i call the dealership friday to find out that they have no started on my car and am told that they will start on it monday. well i decided to give them a few days to work on it. finally today i call and he has an answer for me. it turns out that i have a bent crankshaft, a couple of bent exhaust valves, and a ceased turbo. well the service adviser says that he is going to call me in the morning to give me a few recommendations. what could this be?? should i be scared?? my car only has an exhaust and tein coilovers. should this be covered by the warranty? any input guys?
2005 WRB WRX "was" STAGE 2
cat back
is it an spt and installed by subaru or an other catback?
If its an SPT and installed by subaru you shouldnt have any worries.
if its another brand catback, i think they technically could use that as a grounds to potentially deny the warranty claim, as it is connected to the motor, however we all know a catback isnt going to bend a crank, but still they could use it against you. If they are willing to work, they might cover partial, which is where id assume the recommendations are coming from.
its a greddy ti-c catback. a shop installed it. oh wow...i'm yeah thats going to hurt if they partially cover it. he already told me that if i paid for it myself it would be over $7500. well my fingers are crossed. thanks. i'll post the "recommendations" as soon as i find out.
Yeah regardless of who installed it, its not SPT. I wouldnt get to excited, good luck. IF it is bad news, id look into learning how to fix it your self and save a couple grand and learn about the suby motor in the process.
subie is prity good with the waranties. i had a long discation with my sevice advisor about exhast. if i went turbo back the only thing it wouldnt cover was my exhast.
as long as you havent cracked into the engien or have a tune you should be ok
i have had realy good experance with subies warntie contracts espeshaly with an 05 STi. they are vary touchy about the tranie on thos. i had a syncro and fork going out between 4th 5th and 6th gears. they tor it down to see if it was abuse. i pointed out that most abuse to a trans is in 1st 2nd and 3rd. pluse all my seveces where kept up. so teh rebilt my trany. found out later at my speed shop what hapens between thos gears, the forks have plastick on the tips of them aparently one broke in my tranie.
Dude. SPELL. I'm hear to read and help, not spend 20 minutes deciphering WTF someone is writing..
To the OP.. an STI shortblock, from Subaru, is 1900$.. a gasket kit is 300-ish. used turbos are everywhere, for cheap. you'll also need an oil cooler, and a few other odds ends (t-belt, w/p, etc.) if you pinch pennies, you should be able to get by under 5K$.
Rogan o_0
'01 Dodge 2500 CTD 6-holed hand-shaker - 3850# dual disk
'97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties
ok so just heard from the service adviser and they are proceeding with warranty!!! i getting a new shortblock, heads, and turbo. the recommendations he mentioned were a new battery, change turbo hoses, change powersteering and ac belts, powersteering flush, and new clutch. so i extremely stoked!! my car should be done in a week and a half hopefully.
Rogan o_0
you wont see any real gain till after the tune.
and as far as damaging the engine with the exhaust change with no tune. i relay dont see how.. it jest allows the exhaust to flow a little freer.
now if there where to much back presher that would be a different story especially for a turbo. i have seen flatten vains on some of the diesels i work on due to something casing a restriction from a muffler collapsing or a cat. melting (yes they have cat's)
