Results 1 to 7 of 7
This is a discussion on Why my car spudders and now don't hear BOV? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just installed a 20g turbo on my ej20 motor. I have supporting mods but just never had it tuned ...
    Registered User Saint1's Avatar
    Mar 2009
    Houston, Tx
    I just installed a 20g turbo on my ej20 motor. I have supporting mods but just never had it tuned yet.
    When I am just cruising the car spudders like once for a split second every like 3 mins. When it spudders it makes a squeeky noise for that split second. Also now I can't hear my BOV till I redline and it wasn't like that when I first installed it. I could hear it shifting at like 3 grand.
    I don't know what is wrong with it. Could it be because of not being tuned, because I am starving of gas since I didn't upgrade the fuel pump or injectors. Any help would be really appreciated.
    Thanks
    Administrator TheJ's Avatar
    Dirty South
    I honestly would probably recommend you take it to a shop for some advice and work. If that sounds too expensive, take it back to stock and move on.
    -The J
    New Members, CLICK & BOOKMARK these links:
    Registered User wrx200289's Avatar
    Jul 2008
    co high lands ranch
    Quote Originally Posted by Saint1 View Post
    Thanks
    Ok what BOV do you have.And is the sqeeky noise happing when you are boosting?
    Registered User STiDriven's Avatar
    Apr 2004
    St. Louis
    Yes. You know your 'supposed' to get a tune after a mod like a new turbo or injectors right? Or at the least have a map flashed to your ecu for your given mods. The stock ECU can't control what you have.
    Registered User indytruckboy's Avatar
    Oct 2008
    Reading, PA
    Yea, really. A 20G w/supporting injectors?! On a 2.0? You probably are washing the rings.
    GET A TUNE, SOON. Or catastrophic engine failure is in your future.
    EDIT...... Seriously. I just read the final pair of sentences from your post. YOu said you have a 20G w/supporting mods. No fuel pump or injectors, is not supporting mods. What are you even talking about, supporting mods? Intercooler? You are going to kill your motor if not your trans first.
    I work on vehicles that make 650hp and 2400ft/lbs.
    Oct 2008
    Reading, PA
    And get off the BOV. It's a 20G on a 2.0. Probably doesn't start making boost until past 3,000 rpm even if you did have the proper setup.
    Moderator Donkey's Avatar
    Da boonies
    I just installed a 20g turbo on my ej20 motor. I have supporting mods but just never had it tuned yet. Any help would be really appreciated.
    Thanks
    So you just think the car will tune itself?How do you think the car knows it has bigger injectors?Take the car to a professional.....................jebus.
    2002 FORESTER S
    1998 FORESTER S
