I have a flow bench at work, but none of the supporting literature. Normal procedures for testing newer injectors usually involves cleaning and flow matching, but NOT actual calibration for flow parameters, lest they be from 1998 and older cars. We have the manuals for those...
My question: is 93-94cc a pop correct on the multipoint test for 02-05 wrx 440cc blues? The only guy with knowledge on the machine's use found another job and left asap. They do not look modified, nor do the other set that I have, which flow an even 100cc a piece. They are flowed at 40psi. Thanks for any assistance!
