Head gasket?
Results 1 to 2 of 2
This is a discussion on Head gasket? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ive posted before regarding the DTC p0483 fan performance code and thought it was from an aftermarket thermostat sticking i ...
    Oct 2008
    Holden, Ma
    Head gasket?
    ive posted before regarding the DTC p0483 fan performance code and thought it was from an aftermarket thermostat sticking i had an oem one put in and it didnt change anything the temp gaguge floats up over 3/4 but wont go in the red, mecanic said little bubbbles were in coolant but radiator fins are bent any insight would help
    Pressure test the system. At this stage though even if it is a head gasket you won't know if it's a cause or an effect.
