annoying noise
Results 1 to 7 of 7
This is a discussion on annoying noise within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; When I get on the gas there is this vibrating metal sound, what is it and what can i do ...
    May 2009
    Dayton, OH
    annoying noise
    When I get on the gas there is this vibrating metal sound, what is it and what can i do about it. Thanks
    Try to localize it first. Is it a heat shield rattling? It's not wastegate flutter you're hearing, right?
    Les jeux sont faits.
    May 2009
    Dayton, OH
    Not the wastegate but could be the heatshield, can i take that off without any bad side effects, also looking to upgrade do you know of any sites that i could browse for turbos, would like not to spend a ton of money but want some more hp
  5. #4
    Quote Originally Posted by Evokilla81 View Post
    Not usually but people do it. I'd not. I would remove it to test if it's making the noise though.
    Browse the site vendors. They support the site and are reputable firms subjected to site user feedback here and elsewhere. Keep in mind though that a turbo is bolt on in name only. You will need other parts, meaning more money, so it's not where to start if you're on a budget.
  6. #5
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    If you have a Downpipe, if it's rubbing the transmission crossmember, this will cause a rattling sound. I had this happen when I first installed my dp. More than likely it's the heatshield though!
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  7. #6
    Jun 2006
    If your noise sounds like a clicking sound, Check the contents of the up-pipe. This happened to me probably 3 months after i got my 02' used. I got it from a Volvo dealer actually,,, but it still had factory warranty, saved me a turbo. Turns out the contents of the UP got sucked into the turbo and was disintegrating the fans on the turbo. Car Ran fine, than started to be a little slugish, than one day, I had vacume, but no boost. Figures. They replaced the turbo AND the UP. than Less than a year later, after running a manual boost controller I'm working on my 3rd turbo now. Second one cost me $1300 installed at the dealer
  8. #7
    Registered User 2:43AM's Avatar
    Sep 2008
    NWI
    Slow down, mate! Instead of jumping in head first with your 2nd post with several questions, first research and feel around the forums for a bit. A wealth of information is right under your twinkly fingertips.
