First off...What model and year car do you have? How many miles are on this car? any modifications?...From the info you've given your describing what sounds like one of your outer CV joints has gone bad....Take a look under the car and see if your outer axle joint boots are torn/ or you see grease all over your brake caliper/strut/Lower control arm.....What happens is the boot gets torn (from age and mileage and whatnot) and grease starts to get thrown out of the boot....plus now that theres a hole salt, dirt, and road grime can get in there....and the joint goes bad due to lack of lube and contamination and commonly causes a clicking noise while turning...As a side note...I have the original lower ball joints in my 96 Legacy with over 200k miles...It is def. more common for a Subaru to need a new CV joint than a ball joint...
LinkBack URL
About LinkBacks
but iv got everything fixed except this popping. The sound isn't there with the engine running. But. It will pop when I jack the car up. When going up and weight is coming off the wheel and suspension it pops a couple times. Iv listened but can't tell where its coming from.
