Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
This is a discussion on new to importts - oil consumption? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by littlebro k so im guessing that i have the problem of blown oil seals in my turbo. ...
  1. #31
    Oct 2005
    Late Devonian
    Quote Originally Posted by littlebro View Post
    k so im guessing that i have the problem of blown oil seals in my turbo. I have oil coating the entire inner of my turbo and into my intercooler and even into my throttle body. So what does it take to replace the seals or should i just get a used turbo. Also if i replace the turbo will i have to drain oil and coolant?
    Turbo rebuild:
    TD04 Turbocharger DIY Rebuild Kit (Viggen 9-3 and Aero 9-5 or 9000)
    Turbo swap: http://www.scoobymods.com/forums/tur...41.html?t=7641
  2. #32
    If you had not said "entire inner of my turbo" I'd have said to check your PCV valve. At this stage though it's probably a moot point to do so... I'd still have a look at the PCV since lots of stuff is coming apart anyway I guess.
