Results 1 to 3 of 3
This is a discussion on brake rub within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; well i installed my new brakes and stuff and they work good but they still rub around corners i dont ...
    Apr 2008
    Albany
    brake rub
    well i installed my new brakes and stuff and they work good but they still rub around corners i dont unerstand it.......i greased the pins in the calipar mounting bracket......could i have over tightened the caliper bolts....another thing is my buddy told me to gease the little metal clips where the pad sits....i neeed some advice lol....well here they are anyways....they brake great straight but when i turn not braking they rub
    New brake stuff (pics inside)
    2002 PSM WRX 5mt Hella Slammed/Turboswapped/DomTuned/Daily RIG
    Registered User jefinerng's Avatar
    Mar 2008
    Colorado
    Have you checked your bearings? Even if they aren't growling at you there might be enough play for you to hear your brakes taking a quick corner...
    Apr 2008
    Albany
    i checked the play while the wheel was off the ground at 12 and 6 but it didnt wobble but i have not physical looked at the bearings
