Odd grinding sound
Results 1 to 9 of 9
This is a discussion on Odd grinding sound within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 02 WRX, new clutch and flywheel, full exhaust and intake, stock everything else The sound seems to be coming from ...
    Registered User svynx's Avatar
    Aug 2008
    Hellam, pa
    Odd grinding sound
    The sound seems to be coming from the tranny, but I could be wrong. There are only two driving situations that makes it happen:
    1) engine braking with RPM's higher than 2000 with the majority in the 2000 to 3000 range. Once it drops below 2000, it goes away.
    2) barely on the gas, no acceleration in the same RPM range
    As soon as I add in any accelleration, whether it be very easy, or going full out, the sound goes away. All gears feel fine. Shifts great, and it stays in whatever gear I put it in. I changed the fluid in both diffs...no shavings.
    Any ideas?
    Owner of the Budget Baller
    Bugeye Mafia #201
    Current mods: CAI, SPT exhaust, D-specs w/RCE Yellows, F/R Group N top hats, JDM lip kit, LWFW, F/R sways and endlinks, morettes, tuned at Agile Auto (10/9/10)
    Next project: EvoIII-16g, pnp, 850 injectors, fuel pump, and a little secret.
    Aug 2008
    Hellam, pa
    Ttt
    Bugeye Mafia #201
    May 2009
    madison,WI
    my 03 wrx did same thing
    its the rear diff
  5. #4
    Aug 2008
    Hellam, pa
    Really? I just replaced the fluid in both diffs and neither one had any shavings on the plug. Is it a bearing? I talked to one of my mechanics who is very familiar with the STi's. His first guess was the front diff, or a surrounding heat shield. But, after taking a look, there isn't a heat shield there, so...
    Is there anything that I could do to the rear diff to take it off the list of possible reasons?
    Bugeye Mafia #201
  6. #5
    May 2009
    madison,WI
    Question not sure
    if it were the tranny you would know it cause you would be missing a gear. once one tooth goes the rest follow shortly. which end of the vehicle is the sound coming from?
  7. #6
    Aug 2008
    Hellam, pa
    Sounds like it's coming from the area around my feet, which is why I thought it was the tranny. On the other hand, I have a warped rotor which is making noise, so that might be contributing to the issue as well. But, like you said, if something was wrong with it, there would be a definite sign. Which leads me to the front diff..
    Bugeye Mafia #201
  8. #7
    Apr 2007
    8000' up in Colorado
    Does the sound change with speed and/or rpm? If so, which one(s) and how does it change?
    Scott
  9. #8
    Aug 2008
    Hellam, pa
    Yes to the RPM. It happens in every gear, mainly when engine braking between 2000 and 3000 rpm.
    Bugeye Mafia #201
  10. #9
    May 2009
    madison,WI
    not sure mine was in the rear diff
    but its making the same noise it sounds like, could be front diff or maybe the axle shafts/cv joints or even a wheel bearing
