Turbo? Cluth? Flywheel? Tranny? Whats the problem?
Results 1 to 10 of 10
This is a discussion on Turbo? Cluth? Flywheel? Tranny? Whats the problem? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I got my first Wrx a few weeks ago and am running into some rpm problems. I noticed it while ...
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    I got my first Wrx a few weeks ago and am running into some rpm problems. I noticed it while in 2nd slightly pushing it but not too hard. I got to about 5000 rpm cleanly with average boost. Then the rpm's spiked to 7000 in an instant with no acceleration to match. It was as if the car had dropped into neutral. I wasnt on the clutch and it stayed in gear the whole time. My clutch is starting to go and im replacing that this week. Could it be the clutch going and messing with things or is it a seperate problem?
    Its a 2003 with 97k miles on it
    no upgrades (full exhaust goes on this week)
    Mar 2002
    Calmer than you are
    must be the cluth
    go f*** yourself
    Apr 2009
    CO
    thats kind of what i was thinking.
    So hopefully when i get the new one on in a couple days it will go away. Anyone know of any other reasons? Im hoping the answer to that is no, but just want to be sure
    Aug 2008
    Kennett Square, Pennsylvania
    as mentioned my first approach would be the clutch also...What happens if you nail the gas when your crusing in 3rd gear? Are you hitting your boost targets?
    Apr 2009
    CO
    It takes it a few seconds to get much acceleration or boost if i punch it while cruising in 3rd
    i attribute some of this to the fact that the stock exhaust is still on it but it does seem to be lacking some power. Im not getting the boost numbers i would expect (the gauge is off a little) but even factoring that in im getting 2 to 3 pounds less than i think i should
    Registered User 03SubyWRX's Avatar
    Jan 2009
    Newton Highlands, MA
    Quote Originally Posted by GarrettKoonsman View Post
    Start with the clutch and test it afterwords. Spiking RPMs under high throttle are a sign of heavy clutch wear.
    2003 Subaru Impreza WRX, Kartboy short throw kit, new shifter bushings and rebuildable linkage, Class N Subaru motor and transmission mounts, TiC polyurethane driveline bushings
    Coming Soon: Kartboy pitch stop, Samco IC hoses, and major transmission work.
    Apr 2009
    CO
    thanks for all the imput.
    im almost completely convinced it is the clutch. It is starting to get worse so im driving it the least amount possible and as easy as possible until i get it replaced. The clutch assembly should be in today so hopefully i didnt hurt any other parts while driving it.
    Dec 2003
    Dallas, TX / Sterling, VA
    Your clutch is on it's way out. It should be markedly worse the higher the gear you're in.
    Registered User Sarra's Avatar
    Aug 2008
    Dreadford, OR
    Oddly, when my clutch let go, it would hold on like a bugger in 5th gear, but wouldn't hold on at all in 4th, 3rd, or 2nd. I had 1/128th of an inch before the rivits started eating my flywheel.
    I drove it so long with a bad clutch that I'm still afraid, 5 months later, that if I floor it in 4th on the freeway, it'll slip.
    Apr 2009
    CO
    Thanks for the help.
    The new clutch is going on right now along with full turbo back exhaust . I'll post an update once it is all on and i've driven it for a few days
