Turbo problems
Results 1 to 11 of 11
This is a discussion on Turbo problems within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was underboosting. So I went to cobb and talked to them. The guy told me to adjust the length ...
    Registered User littlebro's Avatar
    Nov 2007
    Turbo problems
    I was underboosting. So I went to cobb and talked to them. The guy told me to adjust the length of my wastegate actuator arm, which would make my boost increase to where it should be. I did this and now I dont have any boost, I now have vacuum. And when I get to around 3000 rpm it whines really loud. Any body know what i need to do?
    Apr 2009
    Montreal
    How many turn have you gave to your arm actuator? If you have lower your spring to much the turbo wastegate will open as soon as there is a little pressure in the vacuum line.
    Aug 2008
    Kennett Square, Pennsylvania
    It kind of sounds like you adjusted it the wrong way.... take a look here...I believe it explains it in there somewhere... http://www.cobbforums.com/forums/ima...mWorksv109.pdf
    Nov 2007
    Alright I was on my way to turbo lab yesterday and all of a sudden I have boost again. Could this have been that it just wasnt adjusting to what i had done? Also I am only getting 13.1 psi and am stage 2. I dont really want to mess with the actuator again. What else is there that i can do or should i just leave it alone.
    Nov 2007
    k so my boost keeps randomly droping down to like 6 psi and then after a bit will go to 11 psi. What is going on? Is this a problem with my turbo or my tune or something else? Also i realized today when i took my intercooler off that there is ALOT of oil in my turbo. When i say alot i mean it is completely black in there. Does this mean time to replace turbo or just seals?
    Registered User redwrx04's Avatar
    Nov 2008
    Santa Fe, NM
    Quote Originally Posted by littlebro View Post
    you should check all your boost lines to make sure there not twisted or have any cracks or leeks. good luck...
    Apr 2009
    Montreal
    Quote Originally Posted by redwrx04 View Post
    +1 I had the exact same problem 2 weeks ago and it was because of a crack in the vacuum line on the side of the restrictor pills.
    Oct 2005
    Late Devonian
    I'd recommend sticking with fixing your wastegate arm first then go from there. Make sure you didn't turn the arm to a funny angle etc. Readjust it so you can feel just a slight touch of spring pressure when you put it back onto the wastegate for now. You should have been turning the end clockwise when viewing from the turbo side to the actuator (end on - i.e. you were supposed to screw the head on further toward the lock nut to shorten the wastegate arm).
    Don't forget to reset the ECU and watch for boost spikes as well.
    Nov 2007
    Alright so i replaced my turbo now. It is one from a 06. I put it on and was only getting around 9 psi. Replaced all the vacuum lines and am getting around 10.5psi now. Ive also tried running with the restictor pill not in. What else could my problem be?
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Get a tune. It sounds like you're just throwing ideas at something that isn't necessarily wrong. Don't run without the restrictor pill in... it'll make you only be able to hit spring pressure, which is around 7lbs of boost.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Nov 2007
    What are you not thinking is wrong. With the accesport i should be boosting closer to 14 psi. And only getting around 10psi. And i only tried without the pill because the guy i bought the turbo from told me to see what it does. He might have been a little confused though.
    So im just trying to see if there are any other ideas anybody on here has that might help me to get my boost where it should be.
