knock sensor code
Results 1 to 6 of 6
This is a discussion on knock sensor code within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi, I have a 1994 jdm wrx, car runs well, pretty clean, when engine gets hot, maybe 30min and more ...
    Apr 2009
    knock sensor code
    Hi,
    I have a 1994 jdm wrx, car runs well, pretty clean, when engine gets hot, maybe 30min and more i may have a check engine with the knock sensor code... and then i gets into protective mode, i guess cuz it wont let me boost, if i had some serious problem, would i hear something not good before the 30 min of running?
    Does it mean my knock sensor gets some incoherant readings when engine is hot, or that there is something wrong with my combistion or anything ... plz help
    Aug 2008
    Kennett Square, Pennsylvania
    If your getting a code for your knock sensor than there is something wrong with either the sensor itself or the wiring...usually its a bad sensor...The older ones at least on the USDM model legacies and imprezas the knock sensor has a tendency to crack...on the face of it (where it mates to the block)...What code is in the car? How many miles?..Do you hear any knocking or anything?
    Apr 2009
    its code 22, i have 70 000km, but cant tell its real, i cant hear any serious knocking not too sure about light knocking tho, im new to the subaru mechanic, engine idle is steady and boosts at 11psi when on normal mode, then after a ride, often on a stop or red light, check engine will apear, but then still cant hear anything anormal, except if i try to boost, it wont let me.
    Im not sure where is the sensor itself, i think its under the intercooler.
    Aug 2008
    On the USDM cars its on the Drivers side (left hand side) kind of right behind the #4 intake runner on the engine itself..you should be able to remove the intercooler and look straight down back there and see it..there should be one wire going to it...
    Apr 2009
    thx bro, here it is, the body is broken
    Aug 2008
    no prob man...thats a pretty big crack...like i said when these Subie knock sensors fail they usually crack right along the side which mates to the engine block...
