Loud Squek.
Results 1 to 11 of 11
This is a discussion on Loud Squek. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I started my car this afternoon and there was a loud squek from my power steering. Once i pull out ...
    Registered User GageP's Avatar
    Dec 2007
    California
    Loud Squek.
    I started my car this afternoon and there was a loud squek from my power steering. Once i pull out of my driveway it stops and doesnt come back for a few hours and then it wont stop. I checked the belts the power steering fluid and they are a fine power sterring fluid is full and the belt is not skipping on the pulley. Dont what else to check, any help would be nice. I have a 2002 Wrx.
    When you do things right people wont be sure you've done anything at all.
    Crabcakes and football thats what Maryland does.
    What does "fine" mean? How old is the belt?
    Dec 2007
    California
    Changed the belt 3 months ago.
    Did you use an authentic Subaru belt?
    If so, see if the pump itself or the roller is making the noise.
    If not, try an authentic Subaru bet.
    Dec 2007
    California
    The power steering pump is binding up when i start the the car, once the car is started and i start to turn the wheel fluid starts to run through it stops. When i have to do U turns it also binds up. I need to get a new power steering pump.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Sounds like you may have done some donuts...
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Dec 2007
    California
    Never done donuts in my car. It has the original pump on the car and the car has 139K on it.
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by GageP View Post
    Well that's good to hear. It's pretty common for steering pumps to fail after donuts.
    I guess you possibly need a new pump. Is there any leakage around the seals?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Dec 2007
    California
    There was some leaks a few months ago nothing major though. I got it on a lift and fixed the leaks. The car has 139k on and i know parts wear out so i know at some point it was going to happen.
    Registered User 2:43AM's Avatar
    Sep 2008
    NWI
    Sounds like you solved the problem. I suspect you knew the answer all along.
    Dec 2007
    California
    Yah i hope, now all i have to do is get a new power steering pump and get it put on, and hope that it sloves the issue.
