Check Engine Light
Results 1 to 6 of 6
This is a discussion on Check Engine Light within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just bought a 2002 WRX from a used car dealer near me. It has 88000 miles on it. When ...
    Registered User Suby Newby's Avatar
    Apr 2009
    SE WI
    Check Engine Light
    I just bought a 2002 WRX from a used car dealer near me. It has 88000 miles on it. When driving the car won't accelerate past 4500 rpm. When it gets to 4500 rpm it almost feels like its hitting overboost as I have experienced that in my Shelby Z. I also notice when driving it it pops or backfires between shifts once and a while. Any ideas? Heres is what was done to the car.
    TurboXS FMIC
    VF34 Turbo
    Bigger injectors
    Invidia DP and Borla catback
    header
    GReddy Turbo Timer
    Manual Boost Controller
    Piggyback ECU. Brand ? I have to check
    AEM CAI
    Here are the codes it reads.
    P0447 Evap emission contol vent circuit open
    P0126 O2 sensor circuit malfunction bank 1 sensor 2
    P0172 System too rich bank 1
    P0301 Misfire 1
    P0302 Misfire 2
    P0303 Misfire 3
    P0304 Misfire 4
    P1139 Control fuel air metering
    P0447 Pending
    P0136 Pending
    P0172 Pending
    The dealer told me the reason the CEL was on was just because of the exhaust so I was mad when I saw all of the codes. Anyone have any input?
    Dec 2003
    Dallas, TX / Sterling, VA
    Looks like you have a bad '02 sensor.
    Apr 2009
    SE WI
    Would it throw most of those codes?
    Dec 2003
    Quote Originally Posted by Suby Newby View Post
    P0301 Misfire 1
    P0302 Misfire 2
    P0303 Misfire 3
    P0304 Misfire 4
    It could throw those. Is your car bogging and hesitating and/or getting bad gas mileage?
    Apr 2009
    SE WI
    Where would that sensor be located and where would be a good place to buy one? Would a chain parts store sensor do the trick? What could cause the evap code? The car actually runs really well, but does cough or hiccup some once and a while. At startup the idle goes up and down some. As for mileage I'm not sure. I've put maybe 100 miles on it so far.
    Apr 2009
    SE WI
    I the car back to the dealer and they fixed the radio and dome lights that weren't working. It was a broken wire. Now the keyless entry works and the tripometer dosn't reset itself when the car is turned off. The car runs better now too. There was a switch on the dash by the fog lights that was set on 0, when its set on 1 it runs like a raped ape. I almost gave myself whiplash when I first stepped on it. I pulled up the carpet and removed the foot plate and the piggyback ecu is a Turbo-XS UTEC unit, its silver and reads says turbo xs which I'm guessing is the older UTEC ecu. After a little reading I found out the switch is for changing maps. The CEL is still on and the car bogs from 1k to 2k so I'm going to check the codes and see if anything changed. Where can I find info on the preset maps?
