Vacuum lines/??/??
Results 1 to 4 of 4
This is a discussion on Vacuum lines/??/?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i recently have finished putting my ej25 into my 2002 wrx. behind the power steering pump there is a sensor ...
    Registered User wrxchris1989's Avatar
    Nov 2008
    Wales, NY
    Vacuum lines/??/??
    i recently have finished putting my ej25 into my 2002 wrx. behind the power steering pump there is a sensor and a bunch of vacuum lines. from the sensor there are 2 lines one is an elbow the other goes to the intake. where does the elbow go to?? and any pictures someone might have would be great. thanks.
    also what sensor is that??
    "When the turbo spools the bulls*it ends."
    BUGEYE MAFIA #210
    Nov 2008
    Wales, NY
    bump
    BUGEYE MAFIA #210
    Aug 2008
    Kennett Square, Pennsylvania
    Is the sensor on a bracket mounted to the intake manifold?...It kind of sounds like your talking about the canister purge solenoid....1 line shound be coming up from under the manifold from the fuel rails up to the sensor and the other should be going to the intake manifold..Which EJ25? Did you swap the whole longblock with the intake manifold and all the sensors? did you reuse anything from the 02 EJ20? http://www.subaru-impreza.org/forum/...noid-valve.jpg Is this the sensor?
  5. #4
    Nov 2008
    Wales, NY
    no thats not it it is bolted to the intake manifold. just the short block everything bolted up nicely i just cant find where those vac lines go. i may just take it to innovative and have them look at it.
    thanks for the help though.
    BUGEYE MAFIA #210
