It looks by your profile that you have an 02 WRX...the fuel filter is extremely easy to change...its bolted to a bracket on the drivers side strut tower...you will see the fuel lines going to it...many people say relieve the fuel pressure first...personally i just wait about 20 min after the car is shut off (so fuel psi kind of drops off) open the gas cap and just undo the lines..make sure you put the filter in the correct direction (it should be marked on it)..I know around 05 Subaru started making the fuel filter part of the fuel pump assembley so obviously the only way to change that is to pull out the FP...This job can easily be done in about 15 minutes...
LinkBack URL
About LinkBacks
'09 STi stage 1, hope this one will be good too...
