1st gear scratching???
Results 1 to 8 of 8
This is a discussion on 1st gear scratching??? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok i just bought my 03 wrx about 1 week ago and it has aprox 60k miles and it drove ...
    Registered User subbi03wrx's Avatar
    Apr 2009
    Houston TX
    Ok i just bought my 03 wrx about 1 week ago and it has aprox 60k miles and it drove fine till tonight when i got to a stop sign and put it into first it grinded going in .... and it will do it everytime going in unless i go from second to first when im gonna take off then it will be smothe.... this is my first wrx so dont kno to much and dont kno if the problem is major hoping some one can help..
    thanks
    what was the problem with your car tho? is it serious? will it damage anything if i keep driving it like that?
    i jusg got an 03 subaru wrx and it has ran great but just tonight it started scratching when i put it into first at a dead stop and dont kno why? it works fine when i put it into second then first before taking off.... if anybody knows what the problem is or has any tips on what to check it would be apreciated....
    thanks
    Flirty User That's Younger Than the Chunks of Corn in Brian's Crap
    WRXie's Avatar
    Mar 2009
    Down South
    Mine did that.
    And then I figured out it was my fault.
    2002 WRX Yellow Blaze
    Bugeye Mafia #216
    High Mileage Club
    WRXie's Avatar
    Mar 2009
    Down South
    With me personally, it was that I wasn't pushing the clutch far enough. I thought that I was but I moved my seat up and hasn't had that problem. Unless I feel lazy and don't push the clutch in all the way or I'm wearing heels. I would try that. I don't know if any other problems with 1st gear.
    Bugeye Mafia #216
    High Mileage Club
    Registered User Replay's Avatar
    Oct 2008
    I used to have the same problem in my MX5 (granted different car) but what it was, I needed to replace the slave cylinder and bleed out the clutch. Does the clutch pedal feel spongy at all?
    Apr 2009
    Houston TX
    Quote Originally Posted by Replay View Post
    nope it feels smooth i seriousley doubt it is that. just this morning i was driving and first would go in a lil rough and wouldnt grind but yesterday it would grind constantly and dont kno why ... i might be low on gear oil .
    anymore comments would be apreciated and thanks for the input man
    Registered User 19josh97's Avatar
    Mar 2009
    Check your fluid.
    Mar 2009
    Synchros go out in 02-03.... Happens to almost everyone... Little grinding going into first... If you want it to stop you pretty much have to up it to the highest grade tranny lube you can get... and learn to not go to first until your to a complete stop... Or it will wear it down completely and you wont be going into first until your under 10 mph.
    Registered User subaru_crazy's Avatar
    May 2004
    NYC
    I have an 02 and my 1st gear started to do that every once in a while about year and a half ago, then last year I replaced the gear oil with castrol synthetic and the grinding went away for the most part. It went down from grinding every couple of days to maybe once or twice a month. I realize that I may have to replace the 1st gear synchro in the near future if I end up keeping the car for the next 3 years or so.
    MY LUG NUTS NEED MORE TORQUE THAN YOUR HONDA MAKES!!!!
    Cobb Stg 2 helix up/dp combo
    Kartboy short shifter
