This is a discussion on Engine is acting funny!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Couple weeks ago i changed out the radiator. Now in the morning when i start my car. It idels high ...
Couple weeks ago i changed out the radiator. Now in the morning when i start my car. It idels high around 2200 rpms and then boggs down to where is sounds like it wants to die. Then repeats the same thing over and over. Its boggs when driving cold, have to rev up higher so it actually goes. But when is at normal driving temp. It drives like normal. Any ideas?????
2009 DGM WRX 5-door w/ STI short shifter. Stock...for now.
So it dosent sound like anything weird which is good. Where is that IACV located?
It does sound like the IACV.
Cleaning And Reattaching The IACV (Idle Air Control Valve) - NASIOC
Thanks, hoppefully its that simple![]()
This is certainly one of those things to try yourself. The dealership RAPES you on this service (experience).
Thats why i thought to ask here first. See if it was something some what straight forward!!! Dealerships are full of subie rapers![]()
Definitely. The dealership would probably charge hundreds of dollars just to clean it. It only takes about 30 minutes to do it yourself if you know what you're doing.
Pick up some carb cleaner and q-tips.![]()
Heh, my local preferred mechanic charged me $20 to clean the IACV when he did my clutch job.
Anyway, if the IACV is, in fact dirty, you clean it, and in the next few months/year, it gets dirty again, clean the PCV system. It'll also help if your air filter or IC gets a bunch of oil on it/in it.
And where did he find the gasket? I've been looking all over SubaruGenuineParts.com || Where Genuine is Better! and SubaruParts.com - Your #1 Source for OEM Parts and Accessories with the part # from the thread over at NASIOC and can't find the gasket anywhere...
