kinda hard to explain plz help
Results 1 to 15 of 28
This is a discussion on kinda hard to explain plz help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so i just got my 2002 Wrx about a week ago so i'm new to Subaru and new to the ...
    Registered User simplyyestb's Avatar
    Mar 2009
    oklahoma
    so i'm new to Subaru and new to the world of turbo
    but anyway i started to get on it last night and right when i hit what should be full stock boost and was at about 4.5k rpm
    the the trouble came
    its hard to explain how it felt but the boost and rpm just kinda bounced and would go back up and then bounce again and it almost felt like i was hitting the break then the gas then the break then the gas over and over
    it doesn't do it every time i get on it but at least half of the time
    i have no idea what is wrong please help!
    i would do a search but i don't know what to search for lol
    so if someone could point me in the right direction that would be great
    thanks
    -thomas
    Registered User baru-by-u's Avatar
    Mar 2009
    Out and about
    what are you mods
    Mar 2009
    oklahoma
    straight up stock
    the guy who owned it before me might have done some stuff to it but if he did he swapped it back to stock
    (side note when the car is off my boost gauge sits just below
    zero shouldn't it be right at zero)
    Registered User Findus11's Avatar
    Nov 2007
    Ketchum, Idaho
    a similar thing happened to my 07... did the exact same thing... I worked on it for about 6 months and turns out the previous owner was quite stupid.
    What ended up fixing the problem was a tune from the Cobb Accessport... Dunno if it'll work, but its a great mod anyways
    Hawk Eye #1991
    Dirty Crew #11
    Military Militia #1991
    I still don't know how I got this car...
    Mar 2009
    oklahoma
    ha thats awesome that thats what fixed it for you do you think it could just be running lean so when full boost there is to much air? so when you got the tune it just fixed your air/fuel ratio???
    Mar 2009
    oklahoma
    Quote Originally Posted by wrx0131 View Post
    If your car is stock, there should be no need to tune it to FIX a lean issue.
    Are you sure there is no boost controller on the car?
    Have you put any gas that wasnt premium (93 or 91)?
    Or another possibility could be a vacuum leak.
    If your car IS running lean, do NOT drive it. You will end up frying your pistons. Been there, done that.
    PS. The gauge should be below zero because you are in vacuum at idle
    yeah there is no boost controller and iv only used 91 (its the highest near me unless i want to go down the highway just to get gas)
    i don't really know that it is running lean its just a guess
    and yeah when the car idles its down in vacuum but when the car is off and keys are out the gauge is just below zero
    not that much but i thought it was supposed to even out perfectly so i thought i would mention it
    Registered User gfred024's Avatar
    May 2006
    ga
    That reading on the boost gauge is at idle? That doesnt look right. Anyone else feel like that? Did you buy it from a dealer? If so take it back and let them fix it. Did you check all you vacuum hoses? If you have a laptop get a tactrix cable and dl ecuflash. Flash a stock rom to it just to be safe.
    Mar 2009
    oklahoma
    Quote Originally Posted by gfred024 View Post
    no that is when the car was off
    i was told by a friend that it was supposed to be at zero
    Jul 2004
    Seattle, WA
    The stock boost gauge reads the actual vacuum, not the ECU.
    When the engine is off it should read 0, because there is no boost or vacuum being produced.
    I have no idea why yours wouldn't read anything but 0 when the engine is off. That's really weird.
    EDIT: Does the Check Engine Light (CEL) come on when the boost fluctuates? When it does get to full boost what does the Gauge read? (It should just below .1 at full boost)
    Can you take a picture of the engine bay for us? Specifically the turbo.
    Many times people will have a downpipe/uppipe or even a turbo upgrade, and have the ECU tuned for it. Then when they go to sell the car, they put the stock stuff back on, and leave the ECU tuned for mods.
    Mar 2009
    oklahoma
    yeah but that is not really what I'm worried about lol
    I'm thinking about just taking it to the nearest Subaru stealership (which is about 1hr away) around the 21st... because i have to go up around there any way for traffic court lol
    so i guess if i cant figure it out by then ill just call the stealership and schedule a "check up"... wonder how much that will cost me...
    Jul 2004
    Seattle, WA
    Quote Originally Posted by simplyyestb View Post
    Best way to find out is to call them
    Mar 2009
    oklahoma
    Quote Originally Posted by jeremy96gase View Post
    no the cel does not come on
    the gauge is below .1 but im not sure how far
    yeah ill take pictures of the engine bay tomorrow after school
    i think he at least had an intake (because there is a screw missing for it at the very front)
    ill do a run tomarrow and video my gauges if i get a chance
    and yeah if its got a tune on it i guess ill have no choice but to get full exhaust intake and go down to able racing and get it re-tuned!
    Oct 2005
    Late Devonian
    Boost guages will not zero correctly depending on atmospheric pressure if they don't calibrate. Elevation is easily noticed by a boost gauge.
    Search for Boost Hunting.
    Registered User s202rxi's Avatar
    May 2008
    Buffalo
    This is true mines looks exactly the same as in the picture when the car is off.
    thanks
    -thomas
    I think i know what your talking about because im kinda have the same issue. Its like a back and forth movement when you realy give it gas?
    Blobeye Syndicate # 111
    2005 WRX OBP 5MT.....Invidia cb, Helix dp, Cobb Ap stg. 2, Intake silencer delete
    Oct 2005
    Late Devonian
    Oh wait, it sounds most like your clutch is slipping now that I read the quote. Your RPM's jump? If so bad clutch. I was distracted by the boost which is just following the load when it slips.
